Question about Electrolux Washing Machines
I have a electrolux We71 washing machine. What does mean E13?
    Habit-Forming:
    New Friend:
  • 62 Answers
Go to this link: And under the heading: Scroll down past the boxes and you will see your code.
Needapplianceparts com
Posted on Jul 03, 2015
6ya staff
SOURCE:
My 7kg Electrolux front load washer keeps stopping from between 1 to 14 minutes before it finishes. I have to keep coming in to press restart button. It keeps saying ERR 10. What does this mean?
Family alarm code E10 means difficulty in filling during wash phase or water leakage.
Could be:
E11 - Tap closed or water pressure too low; Drain tube improperly positioned; Water fill solenoid valve is faulty; Leaks from water circuit on pressure switch; Pressure switch faulty; Wiring faulty; PCB faulty.
E13 - Drain tube improperly positioned; Water pressure too low;
Water fill solenoid valve is faulty; Water circuit on pressure switch is leaking/clogged; Pressure switch faulty.
Dado
Jan 03, 2018 | Electrolux Washing Machines
E13 error code on my electrolux washer what does it mean
You didn't specify model of your washing machine.
For Electrolux that usually means water leaks (Maximum overall water fill time exceeded (sum of all water fills between one drain phase and the next to avoid exceeding the maximum volume).
Could be:
Water fill solenoid valve faulty; Water circuit on pressure switch is
Dado
Mar 03, 2017 | Electrolux Washing Machines
Hi, my Electrolux EWX12550w washing machine and dryer, working fine on was but when I'm drying it it starts at 13 minutes then keeps working but sticks on 10min also I get an err sign it's E10
Family error code E10 is visible to customers and (could be E11,E12 and E13 only visible in service mode) means problem
with filling water.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme).
Press and hold down START/PAUSE and the nearest option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the last alarm.
The alarm sequence continues as long as the two buttons are held down.
E11 - Problems with water fill for washing
E12 - Problems with water fill for drying
E13 - Water leakage
I believe there are difficulties in water fill for drying.
Water is necessary in the drying phase in order to cool down the steam entering in the drying condenser.
Possible causes: Tap closed or water pressure too low; Drain tube improperly positioned; Water fill solenoid valve is faulty; Leaks from water circuit on pressure switch; Pressure switch faulty; Wiring faulty; PCB faulty
Dado
Sep 07, 2015 | Electrolux Washing Machines
How to solve e13 error in risograph ks 800
E13 Cutter motor Lock
• If the Cutter home position switch is not turned OFF within 500 ms after the Cutter motor is activated.
• If the Cutter end position switch is not pressed within 2000 ms after the Cutter motor is activated. http://printcopy.info/?l=en&mod=free&chap=erc&brand=Riso&model=KS800
Apr 17, 2015 | Washing Machines
My Model # EIFLS60JIW0 Serial # 4C21503809 alerted to call customer service error code E13. Can you advise what this code would be in reference to
Dee,
Here is a link to a website that has possible error codes for your machine. I used your model number and went to a different site to find out what brand you had and I am assuming that this is for an Electrolux washer. http://appliance911seabreeze.com/Frigidaire_Error_Code_Booklet.pdf
Mar 02, 2015 | Washing Machines
What is error code e13
Good Afternoon Friend,
I understand that you are receiving an E13 error code on your Electrolux washer, model# EW1000i. In researching the model number you provided, I show that this was manufactured in the UK. For North American washers, I would suggest resetting you appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this, and if it does not work, I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you what the E13 means, as well as assist in clearing it. Hope this is helpful.
-Best Regards-
WP
May 31, 2014 | Electrolux EW1000i Front Load Washer
WHAT DOES E13 MEAN
E13 is for a washing machine door
Nov 05, 2012 | Cars & Trucks
My electrolux IQ Touch came up with error code E13 first time using it what does this mean
The solution for E13 is to unplug the Electrolux washer for a few seconds (10-15 seconds) then plug it back in and press cancel. Then it should reboot itself. It's some problem with the computer which just needs to be reset
Nov 23, 2009 | Electrolux EW1000i Front Load Washer
Error code E10 on the electrolux ecovalve EWF1087 front load washer. What does this mean?
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
Jul 22, 2008 | Electrolux Washing Machines
Washing Machines Logo
101 people viewed this question
Top Electrolux Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Poppa Maddo
Poppa Maddo
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
