Not all oils mix well so completely draining the old oil before refilling is important except where you know what oil is already inside, which I note you don't.
You might find an application for your mixer in one of the online application catalogues - just choose your favourite brand. Most oil brands also have a technical department designed to make such recommendations.
If you can't find a recommendation then what you fill it with is very much your choice - many of the traditional oils for slow rotating gears and bearings have disappeared from the marketplace; the very sticky heavy oils and semi-greases have all but disappeared, some of which were blended with bitumen and some of which had to be warmed in order to make them flow enough to pour.
You could equally choose an SAE 90 or 140 EP (extreme pressure) or even one of the modern semi-synthetic multigrade gear oils such as the SX 75-90 or you could go to the extreme and just use one of the many automatic transmission/power steering fluids that have superior lubrication and cooling properties.
It would be sensible to use an oil that is readily available and there is no reason why you shouldn't use a reasonable quality engine oil as most give a good performance in a gearbox and many vehicle gearboxes have specified engine oil...
Wipe the oil up and use it. The machine has no oil in it, the grease is degrading and the oil is coming from there. It will be fine, next time it needs work done on it have them change the grease in the gearbox.
The oil leeking into your bowl is old grease that has broken down into oil and is getting past your oil seal you need to take out all of your old grease and oil replace it with hi-temp grease or a good grade lithium grease and replace your agitor shaft oil seal
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid
stand mixers are overpacked with oil to last the lifetime of the motor.
If the motor sits idle for some time (is not used), the oil may begin
to drip from the gears and settle. Oil leakage may primarily be seen
from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It
is recommended to run the mixer on speed 10 for 2 minutes in order to
redistribute oil back into the motor. In order to prevent future
occurences, this is recommended to be done every 3 weeks if mixer is
not being used.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
You can use a heavy weight gear oil or call the local hobart branch for it.To remove oil----Look under the mixer where the beater shaft is in the back and you will see a three quarter inch nut,remove this nut and drain the oil then put nut back in.To fill the unit remove the top cover screws and remove the top,you will see a long hexagon nut in length,remove this and grab a funnel then add the oil---be patient it takes time to fill as the oil is heavy.
man you got an oldie but goodie mixer!im a hobart service tech for 8 years and have only seen about two dozen,unfortuantly parts for these units are exhuasted.as for the sight glass they do become cloudy over time and you cant determine the oil level.use a heavy gear case oil.the only way of telling is to drain the oil or if the unit is loud you should probably cange the oil.
