Engine stalls or RPM fluctuates at idle up and down.
This problem
is commonly caused by a dirty automatic idle speed control valve and
throttle valve but always run a OBD2 fault code as well as the
cleaning procedure. Buy a can of throttle valve cleaner (do not use
carburetor spray cleaner!) from NAPA or Carquest (made by CRC
chemicals) and spray it into the air intake while the engine is
running, use up about 1/2 the can, engine will try to stall hold the
speed up, shut it down and let it soak for 30 minutes, restart and
blow out the remaining fluid, shut it down and disconnect the
negative battery cable for 5 Min's to reset the base idle control
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
