RIM Blackberry Playbook with 64GB Internal Memory Dualcore 1GHz Processor Tablet Logo
a
annette Posted on Jul 01, 2015
Why is my camera screen black and I get an error 4003 message?
My BB Playbook Tablet camera screen is black and when I try to take a pic I get a camera error 4003. The S/N# is 1344-2522-9161
Jamie Ehret
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 10, 2015
Jamie Ehret
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
123
Points
I know this may sound lame but have you tried turning your device OFF for 20-30 minutes (not standby)? It's saved my bacon more than a few times... If that doesn't work, try going to
blackberryworld.com. They might be able to help you.
GOOD LUCK!!!
jammers
How do i reinstall playbook on my asus tablet?
go to google play store and type what you need in or type google books
2answers
Erorr code 4003 zebra zxb8
Error Code 4001
System error code 4001 means "The local WINS cannot be deleted." This error code may also display as "ERROR_CAN_NOT_DEL_LOCAL_WINS" or as the value 0xFA1.
Error Code 4002
System error code 4002 means "The importation from the file failed." This error code may also display as "ERROR_STATIC_INIT" or as the value 0xFA2.
Error Code 4003
System error code 4003 means "The backup failed. Was a full backup done before?" This error code may also display as "ERROR_INC_BACKUP" or as the value 0xFA3.
Error Code 4004
System error code 4004 means "The backup failed. Check the directory to which you are backing the database." This error code may also display as "ERROR_FULL_BACKUP" or as the value 0xFA4.
Error Code 4005
System error code 4005 means "The name does not exist in the WINS database." This error code may also display as "ERROR_REC_NON_EXISTENT" or as the value 0xFA5.
Error Code 4006
System error code 4006 means "Replication with a nonconfigured partner is not allowed." This error code may also display as "ERROR_RPL_NOT_ALLOWED" or as the value 0xFA6.
System Error Codes
Blackberry camera 4003 error
Try going into Applications > Camera app and force stop it and clear any cache or data it may have saved. If that doesn't work you may need to factory reset the tablet.
1helpful
Bb playbook Freezed?
My tablet is not working right now... the andiood guy stay on there for long time and it wont go on home screen.... Anyway i can get a replacement new tablet or get it fix or new charger
Playbook camera error
blakberry4003 camera error screen black
Error for blackberry
I just bought a BB Playbook, Initially I got activation error 2012 but then I upgraded it through Desktop manager to OS2.0 but then I get 'Could not activate this tablet error 132353
please advise what to do. I can't use the device
thank you in advance
1. I cannot open the attachments (pdf, excel, etc..), stat to dowload and after inform me that the file is not present on memory. 2. I cannot send email from playbook, and sometimes when BB 9800 is...
Ok, for your first problem, I couldn't open a couple of file types on the playbook at first either. Go to the app world and download the free app called "airbrowser." It lets you do various things such as delete files, and allowed me to find and open the documents I wanted.
As for the email issue, I would suggest retrying the bridge. Go to the bluetooth connections screen on your torch and delete the playbook, and do the same on the playbook to delete the torch. Then start from scratch reconnecting via the BB bridge app. It solved a few issues on my playbook as well.
UNABLE TO READ OLD MESSAGES STORED IN THE SMARTPHONE IN THE PLAYBOOK.
On my playbook when I scroll down the list of email messages and get to a certain point it just downloads more older messages from the phone. If this isn't happening on your playbook, then you should try rebridging the devices. Go to the bluetooth connections screens on both the phone and the playbook and delete the other device from the device list. Then go to the BB bridge app and reconnect them. Hopefully that works.
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
