Cars & Trucks Logo
Emily , Alameeri Posted on Jul 01, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How much should I weigh if I am 74 pounds and 56 inches
Ethan Kunz
Level 2:
Habit-Forming:
New Friend:
  • Expert 63 Answers
  • Posted on Jan 05, 2020
Ethan Kunz
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
63
Questions
0
Helped
10963
Points
230
jay kaye
Level 3:
  • Master 305 Answers
  • Posted on Jul 01, 2015
jay kaye
Master
Level 3:
Answers
305
Questions
Helped
149066
Points
1081
According to the BMI Chart you are underweight. Your BMI is 16.5. A healthy BMI is 20-22 or at your height 95-100 pounds.
This should not be taken as medical advice but only a general guide. Person who are athletic or weightlifters may have different results.
The BMI is an attempt to quantify the amount of tissue mass (muscle, fat, and bone) in an individual, and then categorize that person as underweight, normal weight, overweight, or obese based on that value. However, there is some debate about where on the BMI scale the dividing lines between categories should be placed.[2] Commonly accepted BMI ranges are underweight: under 18.5, normal weight: 18.5 to 25, overweight: 25 to 30, obese: over 30.
How many pounds is 18 gallons
How many pounds are in a gallon?
A gallon is a measure of volume equal to 128 fluid ounces (fl oz). One fluid ounce of water weighs one ounce (oz). So a gallon of water weighs 128 oz, or 8 pounds.
A gallon of other liquids will vary in weight depending on the density of the liquid.
A A costs per kilo
The car weighs about 1820 kg
its current value with reasonable mileage and condtion is about 8,000 pounds.
1820/8000= .22 kg per pound or 4.5 pounds per Kilogram
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
What is the curbside weight for a 1985 dodge pu. Model r15
4900 pounds to 5600 pounds. Depending on the size of the truck. King and quad cabs weigh more. Diesels weigh much more as do super duty trucks.
How much does a gallon weigh
Depends on what you have a gallon of. Water weighs 8.3453 pounds per gallon. Motor oil, being lighter than water, weighs only about 6 pounds per gallon. Other fluids will have varying weights. This is because a gallon is 128 fluid ounces, and a fluid ounce is a measure of volume, not weight.
Why is the sign ,, passenger airbag off'' showing and how do yo switch it on
Passenger airbag goes off if someone sitting in that seat or items weigh less than a certain amount. Not sure the amount because my daughter weighs 65 pounds and light goes off which means airbag wont deploy for her because it would do more harm then good. My son who teeters between 88 - 92 pounds the lights on at 88 and off at 92. So I'm guessing anything under 90 pounds airbag wont deploy. This is what the dealership told me as well when I bought it. I had daughter with me at purchase time.
How many rpm should a 1991 tracker 1.4 auto
The 1991 model was 65 inches high, 142.5 inches long and 64.2 inches wide, with an 86.6-inch wheelbase. Small variations in those dimensions were seen during the course of production, but not more than an inch for any of the measurements. The Tracker is able to tow 1,000 pounds and weighs between 2,238 and 2,338 pounds.Early models of the mini SUV were powered by a 1.6-liter overhead cam 8-valve fuel-injected engine with four inline cylinders, while later models were upgraded to a version of the same engine with 16 valves.The additional valves gave the later models more horsepower and torque. The smaller engine produces 80 horsepower at 5,400 revolutions per minute, and 94 foot-pounds of torque at 3,300 rpm. The larger engine produces 84 horsepower at 5,600 rpm, and 98 foot-pounds of torque at 4,000 rpm. Equipped with an 11.1-gallon fuel tank, the vehicle gets 23 mpg in the city and 24 mpg on the highway with an automatic transmission. With a manual transmission it gets 25 mpg and 27 mpg respectively.
Thanks.
2answers
Can u get to the fuel pump from the trunck
no the fuel pump is located in the fuel tank you would have to lower the feul tank to get to it
Nitrous bottle weight
20 pounds is what it holds, what the bottle weighs depends on what it is made of. A steel bottle and an allumnium one will weigh completly different but still hold the same amount.
5helpful
Looking for the torque specs for 1998 chevy astro van?
1998 chevy astro 4.3 v6 torque specs include :
* foot pounds *
balance shaft (if equiped) gear bolt = step 1 = 15 ft.lbs. step2 = additional 35 degrees.
camshaft sprocket bolt = 18 ft. lbs.
connecting rod cap = step 1 = 20 ft. lbs. step 2 = additional 70 degrees.
crankshaft damper bolt = 74 ft. lbs.
crankshaft oil deflectorbolt/nut = 27 ft.lbs.
cylinder head bolts = step 1 = 15 ft. lbs. step 2 = additional 73 degrees. (tighten in sequence)
exhaust manifold bolts = step 1 = 11 ft. lbs. step 2 = 22 ft. lbs.
flywheel bolt = 74 ft. lbs.
main bearing cap bolts = step 1 = 15 ft. lbs. step 2 = additional 73 degrees.
oil filter adapter bolt = 15 ft. lbs.
oil pan bolt/nut = 18 ft. lbs.
oil pump bolt = 66 ft. lbs.
rocker arm with press in studs = 18 ft. lbs.
rocker arm with screw in studs = 19 ft. lbs.
valve lifter retainer bolt = 12 ft. lbs.
water pump bolt = 33 ft. lbs.
* inch pounds *
balance shaft retaining plate bolt = 106 in. lbs.
camshaft retainer plate bolt = 106 in. lbs.
front cover bolt = 106 in. lbs.
intake manifold upper = step 1 = 44 in. lbs. step 2 = 88 in. lbs.
intake manifold lower = step 1 = 27 in. lbs. step 2 = 106 in. lbs. step 3 = 133 in. lbs. ** (tighten bolts in sequence)
thanks for your vote !
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
