Question about Haier Refrigerators
Where/what site can I find a defrost timer that fits a HAIER refrigerator model RRTG21PABB
I'm trying to fix a fridge (HAIER 21cbft model RRTG21PABB). The guy I have fixing the fridge says I need a defrost timer. The one he pulled from the fridge says 12hr timer 100-120V 50/60hz with Spec# C-3001-56 34minutes Inverses controls. Can't find this part anywhere because there IS NOT A PART NUMBER listed on the part. Also the bottom numbers have 4 3 2 1. Can anyone point me into the right direction on where I can get this dang thing? Or another fridge maker/model that might work. Please and thanks.
    Top Expert:
  • Haier Master
  • 64,245 Answers
  • Ariel Smith
    Ariel Smith Jul 01, 2015
    Thanks but it didn't work.
  • ray gallant
    ray gallant Jul 02, 2015
    didn't work as in did not load or other problem I tried it and it loaded for me
SOURCE:
How can i operate the temperature of the haier fridge model hrf-660aa
do you hear the compressor come on? can u feel it vibrating? if not? bad relay maybe? is there power from the outlet? may also have a bad cold control thermostat or defrost timer? is ther any heat in the freezer compartment?
Feb 16, 2015 | Haier Refrigerators
Why mu refrigerator rrtg21pabb ia working but not freeze
If the refrigerator is not defrosting, the defrost control board might be defective. The defrost control board monitors several conditions and determines how often to run the defrost cycle. If the board fails, the refrigerator will not go into the defrost cycle. Eventually, ice will build up on the evaporator coil and then the refrigerator and or freezer will not stay cold enough. This will depend on where the evaporator is located. It's prudent to check the defrost heater and defrost thermostat for continuity before replacing the defrost control board.
Aug 27, 2014 | Haier RRTG21PABB 20.7 cu ft Two Door...
Why my model HTZ21 JICR55 HAIER IS FROZEN AT THE REFRIGERATOR BOTTON/
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 10, 2011 | Haier Refrigerators
Fridge not cooling
heatman101
Dec 31, 2010 | Haier Convertible Bottom Drawer French...
Top freezer is workiing fridge is not haier preference series htp 18 gaa
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 03, 2010 | Haier (HTQ14JABRSS) Top Freezer...
My fridge freezes everything. What may be the cause? How to fix?
heatman101
Aug 24, 2010 | Haier HSB03 Compact Refrigerator
I have a 20.7 cubic feet Haier frost free refrigerator/freezer, model #HTQ21J*SS and the refrigerator part is not cooling. The freezer is working correctly at the same time.
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 31, 2010 | Haier HTQ 21 JABLSS 20.0 cu. ft. Full Size...
Oklahoma Freezer cold fridge warm fan gets Ice build up !
You should not have to manually defrost. Your auto defrost system is not working. Check the timer usuall in the frig compartment near the thermostat ( a small hole, use a screwdrive flat tip 1/4" to rotate the timer till it clicks starting the defrost cycle) check freezer in 10-15 min should be defrosted if not you will need to check the heater and thermostat located behind the rear or bottom panel of the freezer.
The defrost timer could be under the box in the front behind kick panel or in the rear by the compressor.
Sep 22, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Fridge will not get cold
Was your fridge transported upright at all times? There are warnings on most brands not to lay them down due to potential damage. If that was not the case, those small units are often easy to repair.
[Note to garing: The person said there was no ice anywhere but on the back. Dorm sized refridgerators are rarely frost free, so your answer was pointless.]
Aug 17, 2009 | Haier HSB03 Compact Refrigerator
Refrigerators Logo
149 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
