Just refitted replacement carbs. I forgot to note the position of the 3 petrol lines/pipes from the carbs to the rear of petrol tap.
No where they are breather pipes and allow air it enter the carbs while not letting dirt and grime to get in and cause blockages and also if your carbs do get some sort of blockage or floats get stuck the fuel can exit the carbs instead of pouring into your motor ,and these tubes are also used to take a reading using a vacuum gage while setting up your cabs and getting the fuel and air mixture right
SOURCE: fuel pipes te610 husqvarna
the tank thumbscrew on the left side is you reserve. it needs to connect to the petcock on the right side, across the carb to the top pipe. the petcock should have arrows on it (backside). the bottom petcock pipe goes to the carb. the carbs inlet pipe is on the right side and is adjustable...single screw in the center of inlet pipe allowing it to be rotated for straighter hose connection. that is depending on year of coarse.
SOURCE: honda cbx750f- fuel vent connections on petrol
vent pipe is usually the smaller of the two outlets
SOURCE: I have a Suzuki GS550L 1980. There is petrol pipe
Welcome to fixya Hello I have a solution for this Press Ok, Accept or replay so we may get started Your pre-solution is coming up shortly PLEASE
REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL My name is Bruce
