Question about Xact Communication Sirius XTR8CK Satellite Radio Receiver with Car Kit
I need the color code for a Kraco mdl KGE01G car radio. It has a 9 pin square outlet plug but the wires are exposed are all of a different color. An old radio but it should work. I can wire in behind the plug with power, ground, and speakers if I know the wire code. This way I won't have to tear into the radio and figure the code out myself. Thanks
    Sergeant:
  • 197 Answers
Lots of wiring diagrams online not heard of that one suggest google
Posted on Sep 20, 2017
SOURCE:
Color code radio wires for a 2013 chevy express
Audio Item Wire Color Polarity Wire Location Radio 12V red/white + radio, black 14 pin plug, pin 1 Radio Ground black/white - radio, black 14 pin plug, pin 8 Radio Ignition (low speed GMLAN) Radio Illumination yellow (dimmer) + radio, black 14 pin plug, pin 7 Left Front Speaker (+/-) dk. blue - lt. blue +,- radio, black 14 pin plug, pins 2 - 9 Right Front Speaker (+/-) orange - dk. green +,- radio, black 14 pin plug, pins 3 - 10 Left Rear Speaker (+/-) tan - white +,- radio, purple 16 pin plug, pins 5 - 13 Right Rear Speaker (+/-) tan - orange +,- radio, purple 16 pin plug, pins 6 - 14 Satellite Radio 12 Volts red/white + Digital Radio under driv dash, 16 pin plug, pin 16 Satellite Radio Ground black/white - Digital Radio under driv dash, 16 pin plug, pin 9 Satellite Radio Ignition (low speed GMLAN) Satellite Radio Antenna (coaxial cable) Satellite Audio Left (+/-) brown/white - tan/white +,- Digital Radio, 16 pin plug, pins 2 and 1 Satellite Audio Right (+/-) dk. green/white - gray +,- Digital Radio, 16 pin plug, pins 3 and 4 2016 Chevrolet Express Van Wiring
Feb 16, 2017 | Chevrolet Express Cars & Trucks
What color wire for talk, receive, etc. For it's 4 pin plug
different radios different pins. If you are looking to wire a cobra 29 LTD mic to a Cobra 29 LXLE its the same but to another radio such as a Lafayette it may be different.
Mar 28, 2016 | Radio Communications
Why does my CB only have black and red wires what are they to?
The red wire is your positive wire and the black wire is the negative wire. This hooks up to a car battery or a power supply to turn the radio on.
Sep 06, 2014 | Green Planet Kraco Kp6001h Replacement...
Creative 9 pin male din damaged
The only way to go is Replace the 9 pin adapter. Radio Shack may have the adapter, check them out. You will need to be observant when locating the proper colored wire corresponding with each pin. Two ways to do this and all require a soldering iron. Either split or open the cover on the 9 pin male adapter and expose the wires going to each pin. Identify the colors and pin numbers and draw a diagram on paper to keep for reattaching the wires later on. Cut 1/4 of the insulation back from the end of each wire and tin the wires. In short, hold the solder to the wire ends and heat with the iron so a flow of solder runs along the bare wire. Make certain to put a connector cover onto the wires prior to soldering each wire in place on the pin end. Simply set the correct colored wire end in the proper pin number, hold the iron to the pin back end and allow the wire to affix itself. Do this with all wires. If you do not have 9 wires, that is not unusual, just do the procedure with what wires are available. If you cannot get the outer jacket off of the current 9 pin connecter, then you will need a Volt/Amp meter. Here you simply cut the wire approximately 1/2 to 2/4 Inch back from the cable 9 pin adapter, and locate the pin that corresponds to the colored wire. Using the RESISTANCE part of a meter, when you touch the two probes together the needle moves on the scale. Touch one end to a pin and try each colored wire end until you see the movement on the scale. Now you know what color corresponds with each pin. Solder each colored wire as mentioned above.
Dec 15, 2013 | Creative Technology SBS A200 2 Speakers
I am trying to make use of a 1993 Mitsubishi radio from a 93 Plymouth Colt. The color code I have from an electronics store and what is posted on the internet do not jibe with the wires coming out of the...
best bet , find out where to buy whats called a "free harness" it plugs into youre factory cars radio plug if its intact , then theres wires that are actually marked in silver lettering for power , ground , switched and speakers .ect sounds like youre having a mixed color prooblem cause of the different cars /radio .years of them .if all else fails break out the multimeter
Nov 20, 2009 | Car Audio & Video
Wiring separated from 9 pin female Rs-232c serial adapter
strip off an inch on both ends of the wiring you are trying to connect. Connect each wire with the same color. Example if the 9 pin side wire is yellow/blue then the other end needing to be connected will need to be yellow/blue. Twist them together and use a terminal splicer to fastened and protect them from touching each other. Do this until all wires are spliced together color for color.
May 28, 2009 | Computers & Internet
Audio wiring problem
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Wire: n/a
Radio Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: n/a
Radio Antenna Location: Rear Glass
Front Speakers Size and Location: 6 1/2′ Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size and Location: 6′ x 9′ Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Apr 05, 2009 | 1998 Honda Accord
Need a wire color code for a ford radio f58f-18c815-aa
Notice, this is from the 2005 Ford F150 Wiring Harness. Other radios should be the same or very close. From the main 24 wire connector on back of radio (C290A).
Pin 1- Light Green w/Violet stripe - Voltage always
Pin 2- Light Green w/Yellow - Accessory delay relay output
Pin 3- Light Blue w/Red - Instrument illumination
Pin 4- Black - Ground
Pins 5, 6, & 7 - Not used
Pin 8- Orange w/Light Green - Speaker, left front +
Pin 9- Grey w/Light Blue - Speaker, left rear +
Pin 10- Orange w/Red - Speaker, right rear +
Pin 11- White w/Light Green- Speaker, right front +
Pin 12- Dark Green w/Orange- Speaker, right frt -
Pin 13- Black w/Light Green- Ground
Pin 14- Grey w/Black- Vehicle Speed Signal
Pin 15- Red w/Black- Voltage supplied in Start
Pins 16 & 17- Not used
Pin 18- Light Blue w/Red- steering wheel signal
Pin 19- Dark Green w/Orange- steering wheel return
Pin 20- Dark Blue- Parking Aid mute signal
Pin 21- Light Blue w/White- Speaker, left front -
Pin 22- Tan w/Yellow- Speaker, left rear -
Pin 23- Brown w/Pink- Speaker, right rear -
Pin 24- Not used
Good Luck
Feb 09, 2008 | Car Audio & Video
Xact Communication Sirius XTR8CK Satellite Radio Receiver with Car Kit Logo
141 people viewed this question
Top Xact Communication Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Xact Communication Audio Player and Recorder Expert? Answer questions, earn points and help others
