This is an old post I know
The wash progress lights are giving an error code. With zero meaning OFF and 1 meaning ON your picture shows an error code of 01000000
Switch machine off at the wall for a good 5 minutes. Turn on again and see if the same error again I am afraid this is what the service manual says::
64. (01000000) - Pressure Transducer Error - Frequency < 66 kHz
The Motor Control Module has received signals from the water level
sensor (Ptx) below normal frequency values.
Cause: Faulty Motor Control Module.
Action: Replace Motor Control Module.
The motor control module is found under the buttons panel. Undo the 2 screws at the back behind the buttons and the controller is underneath. You may have to pull the main lid off first to get the buttons panel off. Motor Controllers are not cheap sorry. They can be found on Ebay
MAKE SURE YOU GET THE RIGHT MOTOR CONTROLLER PART NUMBER ON THE STICKER. They may look the same but they are all different.
Unplugging the controller may seem daunting but count how many things you unplug and then you know how many to put back on. The plugs can only fit in their own sockets so you can not mix them up.
Hope this is of some help
Good luck
SOURCE: Fisher Paykel Smart Drive 051
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
SOURCE: How do I engage diagnostic mode?
The tech sheet inside the control panel explains how to do this but I will include an abreviated procedure here.
To enter Diagnostic Mode:
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
