Tip & How-To about Panasonic Tc-50ps14 Tv Power Supply Board Etx2mm747af, Npx747af-1a
Service tool modeHow to access
1. Select [SRV-TOOL] in Service Mode.
2. Press [OK] button on the remote control.
Display of SOS History
SOS History (Number of LED blinking) indication. From left side; Last SOS, before Last, three occurrence before, 2nd occurrence after shipment, 1st occurrence after shipment.
This indication except 2nd and 1st occurrence after shipment will be cleared by [Self-check indication and forced to factory shipment setting].POWER ON TIME/COUNT
Note : To display TIME/COUNT menu, highlight position, then press MUTE for (3sec).
Time : Cumulative power on time, indicated hour : minute by decimal
Count : Number of ON times by decimal
Note : This indication will not be cleared by either of the self-checks or any other command.Exit
1. Disconnect the AC cord from wall outlet.
Hotel mode
1. Purpose
Restrict a function for hotels.
2. Access command to the Hotel mode setup menu In order to display the Hotel mode setup menu, please enter the following command(within 2 second).
[TV] : Vol. [Down] + [REMOTE] : INPUT (3 times)
Then, the Hotel mode setup menu is displayed.
3. To exit the Hotel mode setup menu Disconnect AC power cord from wall outlet.
Troubleshooting Guide
Use the self-check function to test the unit.
1. Checking the IIC bus lines
2. Power LED Blinking timingCheck of the IIC bus linesHow to access
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Exit
Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
FOR MODE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/
USE SEARCH TAB TO FIND MODELS OR USE DROP DOWN MENU
In order to enter Service
Mode, TV guide must be turned off
In order to do this
procedure you must have and use the correct remote. The full function
remote that
came with the set has a TV
Guide Logo in a red box. This is the remote you should use.
NOTE: If TV guide has not
yet been setup, then the 1st step is to follow instructions to set TV
guide up.
Enter ZIP code, cable or
ant. Etc.
1.press and release the
"TV Guide". TV guide will appear on the screen.
2.Navigate to the TV
Guide tool bar and use the ">" button to select "setup"
in the menu and press
and release the
"enter" button
3.use the "arrow
down" button to select "default options"
4.press and release the
"enter" button and select "general defaults"
5.press and release the
"enter" button (opens menu on lower left side)
6. use the "arrow
down" button to select "auto guide"
7. use the ">"
button to select "off"
8. use the "arrow
down" button to select "done"
9. press and release the
"enter"
10. press and release the
"TV Guide" button to turn the display off
System Reset
Using Service Mode:
1.
Enter Service Mode
2.
Use the "muting" button to select "initialize"
screen
3.
While on the "initialize" screen
4.
Use the "down arrow" button to select "final setup"
5.
Press and release the "enter" button to select "data reset"
6.
Use the ">" button on the remote to select "yes"
7.
Press and hold the "enter" button until the screen goes
black release "enter" button on remote.
8.
Power the unit off using the remote control
9.
Unplug the power cord from the media receiver to complete the reset
10.
Plug in the media receiver; turn the system on and reset is complete.
ok
