I am not shore exactly Where the safty stat on that model is situated. Check right underneth the controlle box underneth the oven there should be a little round plastic screw cap looks like a fuse holder unscrew cap and press the reset button. If it is not underneath the oven switch off main power supply and open back cover on oven and look for safty stat (all though there is 2 types of stats )1st type is a square silver box with 2 or more electrical wires connected to it with a thin silver wire on it that goes into the oven baking chamber and it got a small red reset button on it just press reset button.2nd type looks like firs type but do not have a reset button this one will have a dial on it. "If it is 2nd type it can not be reset it needs to be replaced"but you can turn the dail and listen out for a click sound if you can hear a click sound it NORMALLY means the stat is still working and you got a nother fault somewhere if there is no click sound replace stat with one that got the same values as the original stat and make shore you set it the same temperature the original one was set on
