Motor runs constantly but freezer does not freeze the contents.
Sound like a typical low freon Issue. Check out our articular on recharging residential refrigerators and freezers
On Time Appliance
If it Helped follow us on our Google plus page.
On Time Appliance Google
SOURCE: vulcan freezer 300lt
Before you condem the temp. control,Check freon level.If the freon level is low the unit will not get cold enough to satisfy the temp. contol.
SOURCE: freezer freezes but does ever stop running
thermostat is stuck on! set to medium setting and gently tap stat. does it turn off? it was stuck. does it still run? its still stuck. if you feel comfortable find stat and power in and out. disconnect - it has to turn off then. but 99 % of the time its the stat. they fail closed and run 24 -7 or fail open and temps get real hot and they never close and restart compressor . yours appears to have failed closed. sometimes you can firmly twist em max cold to min cold a few times and break the stuck contacts and they'll do ok for a while. try to reset at a little higher or warmer temp when done so its not making and breaking on the same old worn spot again. good luck.
SOURCE: Freezer motor keeps freezing up
Sounds like a defrost timer.Also it can be a defrost thermostat.Try to adcance the defrost timer to a defrost and see if it melts the ice off.If so then i would say you need a defrost timer hope i helped:)
SOURCE: The freezer is running, and
Hi and welcome to FixYa. I am Kelly
If your sure the compressor is running and it is not freezing then there has to be a system coolant leak.
Having said that there are a few things to check:
1. Is the compressor in fact running Y / N
a. Yes = coolant level problem or coolant system blockage
b. Not running = (Possibilites below)
1) PTC / Klixon Thermal overload failure
2) Run capacitor failure
3) Temp control failure
4) Automatic defrost thermostat or thermistor
5) Defrost timer or Adaptive defrost control failure (depending on model)
2. Is the compressor very hot to the touch or room temp?
a. VERY hot = unplug the unit for at least 30 minutes and then plug it back in.
b. ROOM temp = any of the above in 1b items 1) - 5)
3. Is the evaporator fan running?
a. Yes = Temp control is ok Defrost system is probably ok
b. No = same as 2b
With a model number I could pass on a few additional things to do. For the moment use the above.
Thanks for choosing FixYa,
Kelly
