HTC Desire Cell Phone Logo
D
D Pilkington Posted on Jun 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My HTC cell phone will not turn on. I have charged it all night.
S H O
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Jun 29, 2015
S H O
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
1945
Points
22
Previous answers regarding battery failure lead you to the mostly likely source of ypur problem. It most likely is as simple as a dirty contact, or a defunct charger or charging cable, or a shorted battery that can no longer be charged. On the other end of the spectrum: your phone itself may have died (a burned out circuit board, an internal short or open circuit, or another catastrophic failure) and cannot be fixed. Start checking, as previous posts indicate, at the simplest possible cause, and go down the list, in order:
1. Clean all contacts (use a clean pencil eraser, electrical Crocus paper, or a commercial contact cleaner).
2. Substitute a different/new charging cable (they very frequently fail).
3. Substitute a different/new charger (they, too, sometimes burn out).
4. Substitute a different/new battery.
Hopefully, you'll find the fix above to be simple and not very expensive.
But... If these attempts don't work, it is likely a failure of the phone itself, which would leave you with two expensive options: Have it repaired - which would probably cost more than the phone is worth - or replaced. Unless you have vital data on the phone that you have neglected to back up (!), replacement would be the no-brainer choice: your phone is probably due for an upgrade anyway. It's terrible to think of it this way, but cell phones, even smartphones, are designed to be disposables, to be replaced about every two years. A repair, if even possible, is likely to cost in the hundreds of dollars. And, you have to pay whether it can be fixed or not. Only you can decide if it would be worth it all!
BTW: If the phone has truly failed and you MUST retrieve vital data, there are data recovery services that can attempt to recover it from the dead phone's memory, if it is not corrupted or encrypted. The services are expensive (check online), but may be your last resort. This is why regular backing up of data is so important. All electronic gadgets eventually fail!
Dan Apthorp
Level 3:
  • HTC Master 2,824 Answers
Dan Apthorp
HTC Master
Level 3:
Answers
2824
Questions
0
Helped
889987
Points
7391
Is the battery good My phone would not work till I replaced the old battery,
3 Related Answers
Anonymous
  • 6 Answers
  • Posted on May 13, 2009
SOURCE: i can't turn on my cell phone htc 3125 now after i
remove your battery and try to clean its contacts,as well as the power connector from the main board.
270rexton
270rexton
  • 782 Answers
  • Posted on Sep 25, 2009
SOURCE: my htc touch pro wont turn on after being charged all night
Had the same problem. You need new battery! (borrow from friend, if anyone has HTC to test if phone is OK with different battery).
Testimonial: "holy crsp it worked thanx:)"
Anonymous
  • 1382 Answers
  • Posted on Jun 20, 2010
SOURCE: unlock htc 8925 cell phone
You can get the unlock code by contacting your current service provider customer care department.If your phone is locked you can use any of your friends phone to make this call. The service provider will then provide you the unlocking codes.. Remember that the reason why the codes are provided only thro customer service provider is they will make a check on your name and identity proof at the time of your call. If the information is found to be correct and matching with their data then you will be provided with the codes. Everything is done for free of cost and you are not going to be charged for this process.This is the universal solution and is useful for many customers who are facing these kind of problems. Don't believe in any websites which provides unlock codes. All are fake. Only your service provider can provide these codes.
Thank you !!
1helpful
My htc 8s wont charge
Do not do a hard reset,you don't need to. Hold the power button down for twenty seconds and the phone will reboot itself.
2answers
My htc wont change and just fashes a red light
your power supply is overloaded, check the power supply of your phone
Htc aria wont fully charge
I had the same problem with my droid 2 before i got rid of it for my iphone. I took it back to the store and they said," the battery is done with its life." lol. i got a new battery and it fully charged after that until i sold it. Also my friend had the same problem but his was his charger.
Hope this helps
5helpful
My htc touch pro wont turn on after being charged all night
1helpful
2answers
My HTC Touch Pro turns completely off in the middle of the night
I think I have found out the way to solve this problem! I think! Ok on my phone I changed the power settings. Go to settings>all settings(if on touch flo)>system tab>power>advanced tab> then uncheck the two boxes that says "turn off device if not used for". Hopefully this works because I don't want to trade in my htc for another phone. Try it out and let me know if this works for you or not.
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
