AJ Andile Posted on Jun 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bizhub 420 is showing me a C2801 code please help if u have an idea.
Harish Kumar
Level 2:
Habit-Forming:
  • Expert 166 Answers
  • Posted on Jun 29, 2015
Harish Kumar
Expert
Level 2:
Habit-Forming:
Answers
166
Questions
Helped
59048
Points
293
Please explain as per documentation what is C2801 error code I can help you
5 Related Answers
Everett Lin
  • 990 Answers
  • Posted on Feb 07, 2009
SOURCE: WORKCENTRE PRO 420 U9 CODE
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
Anonymous
  • 77 Answers
  • Posted on Sep 07, 2009
SOURCE: what is the problem code c-2801 in my konica
Have you check the Printer control board. Also does the toner bottle turn? You can force it in 47 Mode. to turn the bottle motor CW or CCW
Anonymous
  • 158 Answers
  • Posted on Nov 21, 2009
SOURCE: minolta bizhub 420 code c2403
this error code means there is a problem with the toner bottle drive most likely the toner rotation sensor will need to be replaced
Anonymous
  • 32 Answers
  • Posted on Aug 15, 2010
SOURCE: How to fix Error Code C3901 on a Minolta Bizhub
Enter service mode & Clear All
Utility>Stop>0>0>Stop>0>1
All of this within 3 secs.
Please Rate me.
Anonymous
  • Posted on Dec 12, 2010
SOURCE: bizhub 420 error code c-2801
konica minolta bizhub 420
error code 2801 plesce relese the code prectical met
I have a bizhub 361 with a error code C1102 and one with code C2801
1102 is output tray lift motor did it hit something on the way down? 2801 replace the drum and developer
Error code C2801 for Bizhub 750
When was the last time the developer was replaced in the developer unit? If has been replaced then you might have a bad ATDC (Automatic Toner Density Control) sensor Located at the rear of the drum and below. (Remove drum to see, has a white cover on it attached to a control board, needs cleaning,2nd replace. If the developer was replaced when it was done was a vacuum cleaner used? IF so the static electricity from the vacuum clear destroyed the sensor, NEVER USE a VACUUM cleaner to remove the developer. Also when the developer was replaced, was counter cleared to tell the copier developer was replaced, the copier use the counters to determine certain voltages for certain assemblies, if not image problems and codes can appear. Finally was the F8 run after the developer was installed before any prints or copies made? If not buy new developer and start over, counter is to be cleared first, then developer replaced, then F8 run.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Develop ineo 420 error code c2801
replace the developer and run the required F8, BUT FIRST MUST CLEAR THE COUNTER for developer before removing developer unit.
2helpful
Konica bizhub 501 take code c2806
actually code c28xx have 7 variant. for example, c2801, c2802, c2803 (error 3,4,5,6) and c2804. if follow the code code c28xx is TCR output abnormality.
ok, first you clean T/S block, do servicing and cleaning all parts.
second, if still same, do toner auto supply.
third, trouble reset. off your machine first, press and hold utility/counter and on machine, until trouble reset appear. press it and off/on again. ^^,
Error code c2801
Maximum density correction problem.Clean the AIDC sensor located under OPC drum.
10helpful
2answers
Bizhub 500 show code c2801
sir i have a bizhub Minolta 500,the problem is that it shows the code c-2801 and out put trays are not working ,when i start the machine and code is shown and machine is not stared please help me its urgent case
1helpful
2answers
My konica minolta bizhub 361 has an error code c-2801.... what does that mean?
In my experience you have to change the developer and the machine will be ok.Also there is a chance that you have to clean the two toner sensor that are located in the end of the toner bottle,sometimes there is the problem.please let me know.
5helpful
Please: malfunction detected c2801 konica minolta starter
bizhub 600/750 warming up and error 2801
please help
18helpful
2answers
Bizhub 420 error code c-2801
k24674
ADMIN Andrew
ADMIN Andrew
