Computers & Internet Logo
Sean Depass Posted on Jun 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It just shut down one day not coming on battery was full
Gar
Level 2:
  • Expert 384 Answers
  • Posted on Jul 01, 2015
Gar
Expert
Level 2:
Answers
384
Questions
Helped
162368
Points
779
Pretty vague, but I'll give it a shot. Remove the battery and try to boot while plugged into the wall.
If you get nothing, no power lights, no screen, etc, your power adapter is bad, the plug in connector is bad, on/off switch failed or you have serious problems with the PC. Can't diagnose with the limited info you provided.
Try the same thing with the battery installed and power adapter unplugged.
There are many, many more things that would cause this, but like I said, can't diagnose with limited info.
Battery drains down after 2 days. 2001 Silverado 1500 extended cab. when truck shut down after 45 seconds gauges come back on killing battery. pulled fuses in engine compt. with milla amp test in line ,no...
The only realistic way the gauges can come back on is if there is a problem with your ignition switch - it is not staying off in the off position. The switch is located at the bottom of the steering column and may have come loose, may be misaligned or may be faulty.
Phone shut itself down, won't come back on
how old is the phone and more specifically, the battery? rechargeable batteries, unfortunately, do not last forever. i used to have a phone that didn't need charging for days. over time (a few years), i had to charge every night.
will it turn on while plugged in? if so, then it's probably the battery.
1helpful
Media full Shutting down
Check the battery in it. It may require replacement. Also it may be infected with a virus or it's firmware has become corrupted.
2answers
One minutes Battery meter shows full, the next 0% Battery Low
Have you tried powering the phone off and removing the battery? Cleaning the charging contacts on the phone and the charger? Inspect the charging port to make sure there wasn't any damage from the fall. Then restart the device.
Hope that helps.
Blackberry bold suddenly shut down
Lots of battery issues with the Bold. Try taking the battery out, keeping it out and connecting to PC with USB. Do any lights come on? Red light should appear. Put battery in while connected to USB.
Another fix that I found for a friend-leave the battery out of the unit for a day-put it in and plug in power cord or USB. It worked.
Air Conditioning system 97 deville
Look for a high side pressure sensor. It sounds like something is tripping an A/C code.
Turn On Problem
Are you sure you are actually shutting down and not entering sleep mode? Sleep mode does use power while it appears to be off, it resumes instead of powering on. Have you tried removing the battery when charged and allowing it to sit over night or a full day then check the charge level. If the battery discharges regardless of being inserted, then the battery is at fault.
2answers
Battery Problem
take out the battery, let set for a few min. and put it back in, try it. If does not work you need a new battery
Samsung a570
nope i had 1 an i threw it in the wall twice it comes up and work but even on a full bat it shows low bat....(it never dieed nor turned off)
Grand Canyon Tech
Grand Canyon Tech
