Danby DWC283BLS Wine Cooler Logo
m
mark matejovsky Posted on Jun 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My danby wine cooler is not keeping set temperature on lower level. Always reads 32 degrees. Set at 46 degrees
On-Time Appliance
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Expert 114 Answers
  • Posted on Jun 29, 2015
On-Time Appliance
Expert
Level 2:
Passionate:
Answers
114
Questions
0
Helped
56458
Points
381
Sounds like your getting low on freon. Check out our video and hope it helps.
5 Related Answers
Timothy Snead
  • 6 Answers
  • Posted on May 27, 2008
SOURCE: danby wine cooler repair
call Danby at 800 263 2629, you can order parts from them
Anonymous
  • Posted on Jul 06, 2008
SOURCE: how to reset the temperature on the danby silhouette wine refrigerator
This happened to me, I found that the cooler would not go below 70 degrees because the cooler had lost its coolant or wouldn't work. I do not know, but as it was under warranty, an appliance repairman came and said that it was worth fixing, so it was replaced with in a week. Normally you would just hole the button in until the desired temperature is selected. Once released the cooler would attempt to set this temperature. If it is not, then I suspect it too is broken. Good luck.
Anonymous
  • 750 Answers
  • Posted on Sep 28, 2008
SOURCE: E4 Code
Dear moriquenda
welcome to fixya.
Did you try resetting the system by pulling the plug and waiting 5 minutes then restarting the wine cooler?This may solve you problem.
Danby expects customers to call service and does not imagine the rest of the world being able to utilize these codes.
Closed minded, Huh?
Please remember to leave a rating!
Huuum
Anonymous
  • 44 Answers
  • Posted on Aug 21, 2009
SOURCE: danby wine cooler compresser not running and is hot
The compressor needs to be tested to see if it's operational. This normally needs to be done by a service tec.
Anonymous
  • Posted on May 13, 2012
SOURCE: Danby DWC283BLS Wine Cooler - Error message E3 & E4
E4 on danby designer wine cooler -
TEST your compressor: Cooler can be forced to operate and cool as a test.
Unplug unit from 115v receptacle.
Hold both temperature control buttons down.
Plug unit in 115v receptacle.
The cooler should start, but the thermostat will not stop the compressor. Now you got a freezer ! I do not know how to fix the E4 error yet.
How do I fix a 2 Whirlpool/Danby WWC287BLS 2 zone wine cooler with 1 zone that operates correctly at set temperature but the other zone gets way too cold (36 degrees) and the compressor keeps running.
Check to see if the thermostat is possibly being blocked by something. If one zone is working correctly there must be an obstruction or problem with the thermostat sensor.
Sorry can't be of more help
Nov 24, 2014 • Furniture
I cannot set the temperature ... Keeps resting 75 degrees F
How long does it take to reset? What is the temp are you trying to set it to? How old is the unit? Has it always done this or just started?
I just bought a dual zone wine cooler. What temperatures should I set both compartments to?
Red wine should be stored between 58-68 degrees Fahrenheit and the whites should be cooled at 46-56 degrees.
Jul 31, 2012 • Furniture
Upper & lower level does not cool. Temperature stays at 78 for lower level & 75 for upper. In attempting to set cooler temperature at 55 for top and 45 for lower it immediately reverts back to 78...
take shelves off. temp display unit in middle of shelf is where circuit board is for testing. pull middle unit forward and unscrew back panel. check lines for leak. color should look like a teal green. thats where your leak will be. Need tech. for the rest.......good luck!!!!
1helpful
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
3helpful
What is the temperature setting for normal wine cooling?
It's between 55 and 65 degrees fahrenheit. If you're storing a lighter red wine, you'd want to keep it on the lower end (55 degrees). And for the darker (deep) red, you'd want to keep it on the higher end (65 degrees). All white wines should be on the lower end, and below. You can drop down to 50 degrees if you'd like. I hope this helps. Good Luck!
4helpful
How to reset the temperature on the danby silhouette wine refrigerator
3answers
Three Temperature zones
Did you read the owners manual? It will be kind of hard to tell you because there are so many different settings for different areas.
Top Danby Furniture Experts
ZJ Limited
ZJ Limited
Are you a Danby Furniture Expert? Answer questions, earn points and help others
