SOURCE: bosch classixx 6 1400 machine
F21 relates to a motor or control board fault. However, it is also caused by spikes in the mains and can be spurious. To reset it. Turn the appliance knob to the off or reset position, 12 o'clock. Turn the knob to the 6 o'clock position. Press and hold the spin button. While holding it, turn the knob to the 7 o'clock position. Continue holding the spin button for about 5 seconds. Release the button. Turn the knob to off. When your turn it back on it should have cleared the error code
SOURCE: I have a Bosch Classixx
F21 is a motor or control board fault.
This also can be caused by voltage spikes or surges...
To reset it.
Release the button.
If the problem continues then check the motor...
heatman101
SOURCE: Bosch Exxcel Washer F21 error code
got a bosch washing manchine it keeps coming up f21 error and i have no book 2 see wot it is can you help me by tellin me wot it is thanks
SOURCE: Bosch Classixx 6 1200 express has an error code F21 what is it
it is a motor or pcb fault this is a reset code as follows,
turn dial to off 12 0clock position then turn to 6 oclock,
press and hold the spin buttonat same time turn it to 7 oclock,continue to hold the spin buttonfor 5 seconds,release button,turn off.
next time you turn on the error code should have gone ,
if it does not work go through the proceedure again i had to try it 3 times but it does work
SOURCE: He2 plus front load washer
If you found a blockage in the pump screen restricting the drainage and it now drains fine but F21 is still there,the error code can be cleared by pushing the PAUSE/CANCEL 2 times within 2 seconds.
If after clearing the error code if it returns on the next wash cycle the pump will need to be replaced.
I hope this has helped you resolve your washer troubles,
Gene
To reset it.
Whilst holding it, turn the knob to the 7 o'clock position.
Release the button.
When your turn it back on it should have cleared the error code.
To reset it.
Release the button.
