Radio Communications Logo
R
Richard Titus Posted on Jun 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My jabra journey hsf003 voice control doesn't work? Only beeps
I can turn voice control on, but I can't make a call with it. When I tap the voice button all it does is beep and the blue light flashes? Can anyone help? It did used to work.
johnny rebel
Level 3:
Top Expert:
  • Jabra Master 10,875 Answers
  • Posted on Jun 27, 2015
 johnny rebel
Jabra Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2939893
Points
47944
Then it is probably time for a new one
1helpful
How.do.i get my jabra extreme 2 speak englidh
They are sold with the firmware and language for the country they are selling to. You have to change the firmware to your country. Easy to do with a computer.
How do I change the voice guidance language? ' Jabra ...
www.jabra.com > ... > Frequently Asked Questions
To change the language of your device, you must upgrade the firmware with the ... How do I manually turn off/on voice guidance on my Jabra Extreme2?How do ...
Jabra Extreme 2 ' Jabra Support
www.jabra.ca > Support > Jabra Extreme 2
Get support for your Jabra Extreme 2. Find all product guides, resources and FAQs.
What is voice guidance? ' Jabra Extreme 2 ' Frequently Asked ...
www.jabra.ca > ... > Frequently Asked Questions
How do I reset my Jabra Extreme2?How do I pair my Jabra Extreme2 with my mobile device?How do I update the firmware or change the language on my Jabra ...
Jabra freeway only emits beeps not commands
Turn the device off. Press and hold the voice button and slide the power button into the on position you should hear the device say "Voice on"
Auto connect/disconnect
Hi. To turn Voice Guidance off, press the Option button. To find the settings, press up or down slowly until you hear a beep. Press OK to enter the voice guidance menu. From that his menu: Voice Guidance On/Off: Use arrow keys on remote to toggle on and off. NOTE:This menu is spoken even when voice guidance is turned off.
Read more: Turn off voice guidance Jabra extreme 2? - Software to turn off voice guidance of jabra extreme 2 :: Ask Me Fast at
9helpful
4answers
Resetting my jabra extreme 2
If your Jabra Extreme2 Voice guidance is not turned on - i.e. you only hear beeps when you power on or a call comes in...
Cause: powered on or off with answer button depressed
Solution:
1) Power off
2) Hold down answer button (the one that lights up Jabra)
3) Power on
4) Release answer button
You may need to repeat.
My Jabra Journey device do not talk anymore. It does not say "connected" or "disconnected" or the in-coming call phone numbers. It only makes a musical sound
Okay, I had the same problem of Jabra Journey not talking anymore, 'voice on connected "etc. And instead it only made sounds like bing bing... Here's the answer and its so simple! Turn the unit off with the slider off/on switch, (symbols are - or o). Then, press and hold the button at the very end of the unit, (symbol looks something like sound waves), while sliding the power back on. That's all there is to it and you'll hear it start talking again.
Technical support for jabra journey MODEL HFS003
Can I connect my Jabra Journey Model HFS003 to my car radio to listen music, conversations, etc by my speaker's car?
I do not have manual for jabra bt160 how do i connect to phone
Wear it how you like it 4
5
English
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2 )
For optimal performance,wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight.In general,you will get better performance when
there are no obstructions between your headset and your mobile phone.(See fig.5 )
Answer a call
Tap the answer/eend button on your headset to answer a call
End a call
Tap the answer/eend button to end an active call
Reject a call (DDependent on your phone supporting this feature)
Press the answer/eend button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (ssubject to phone
settings) automatically transfer to your headset
Activate voice dialing (DDependent on your phone supporting this feature)
Tap the answer/eend button. For best results, record the voice-dialing tag through
your headset. Please consult your phone ’ s user manual for more information about
using this feature
Redial last number (DDependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+or – ) to adjust the volume (See fig. 1 )
How to...5
Before you use your Jabra BT160, you need to pair it with your mobile phone.
1. Put the headset in pairing 2 mode
Make sure that the headset is on.
Press the answer/eend button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘ discover ’ the Jabra BT160
Follow your phone ’ s instruction guide. This usually involves going to a ‘ setup,’
‘ connect ’ or ‘B luetooth ’ menu on your phone and selecting the option to ‘ discover ’
or ‘ add ’ a Bluetooth device.** (See example from a typical mobile phone in fig. 4 )
Pair it with your phone 3
English
Turn on your headset 2
Press the answer/eend button to turn on your headset
Press and hold the answer/eend button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
The Jabra BT160 is easy to operate. The answer/eend button on the headset performs
different functions depending on how long you press it.
Instruction:Duration of press:
Tap Press briefly
Press Approx: 1 second
Press and hold Approx: 5 seconds
Getting started
3. Your phone will find the Jabra BT160
Your phone then asks if you want to pair with it. Accept by pressing ‘ Yes ’ or ‘ OK ’ on
the phone and confirm with the passkey or PIN 3 = 0000 (44 zeros).
Your phone will confirm when pairing is complete. In case of unsuccessful pairing,
repeat steps 1 to 3.
http://www.jabra.com/Sites/Jabra/UK-uk/support/Pages/JabraBT160.aspx
It is all in there www.jabra.com
ARTGIRL
6helpful
4answers
Jabra bluetooth headset
how do I set up the phone to discover jabra vbt185z?
2answers
Jabra bt160
hold the button down for a long time
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
