This is a very common problem when the condesate drain behind the rear of your freezer wall becomes clogged with ice or other matter. If this is happining only under ther refrigerator it would indicate a drain pipe missing the condensate tray or the tray itself is cracked or leaking. Click here for moer= Leaking Refrigerators Just what may be happing and then here=> Leaking Refrigerators
Please read all the information because all leaking refrigerators act differently. I will be here should you have more questions, Thank You, Sea Breeze
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
oil burning bad lifter bad valve pluged converter head might be cracked bad injector.you got the codes to fix itand you did but there a reason this problem keeps coming up find it before it dont run I dont know this code but the reason it comes up is a problem look in to it moore ......
Should have a drain hole on back to drain outside it maybe pluged or unit is not leveled to outside has to have a slight tilt for water to drain out not in.
MAKE SURE EVERYTHING THAT IS PLUGED INTO THE
PHONE JACKS HAS A DSL FILTER PLUGED INLINE. DO NOT FILTER THE ROUTER...IF THAT DOES NOT HELP THEN CALL YOUR LOCAL PHONE COMPANY TO INSTALL A WHOLE HOUSE FILTER IN THE BOX ON THE SIDE OF THE HOUSE....
Take it to a ac specialist.. The will put in some coolant and also put in a die.. They will chaeck it again in a few days with a floresant light that wil pick up were the die is coming out.. Could be a leak at a hose..
sounds like you need to tighten connections on the housing drain tube with replacement of houses on vehicle replace drain tube
but also it could just be condesation from a/c this is normal
