I FUJI XEROX printer CM215 fw indicates the error code of 092-651 with a sub code 25d0000. I do not know what this means or how to fix it. Thank you for the help.
Do you have another kit you can take from another printer.
Switch the printer off.
Swap out the kit with the one from the other printer.
Turn it back on. If it clears the fault when the printer is ready put back the new kit
The default ID and password are "11111" and "x-admin" respectively. When accessing the administrator menus on the copier the code 11111 is used. I couldn't find a way to reset specifically.
I believe you should be able to access the Admin Menu by pressing the System button on the operator panel. A password is required to enter Admin Menu when Panel Lock Set is set to Enable. To Disable the Panel Lock you will need a password. The factory default panel password is 0000. Hopefully you haven't changed that. This procedure is described in the manual on pages 315 ff. I believe from there you can go in and assign a new Admin password if required.
Printer CM205 b error code 092-651
Options
My printer FUJI XEROX CM205b is showing an error code of 092-651 with a sub code of 2080000. I have no idea what this means or how to go about fixing it. this has been a great printer and would like to fix it if possible.
Defective IIt/IPS board. Is very expensive. Call you local Xerox service number and ask them for part number 160K99811 and how much it would cost to get it fixed.
