Question about Yukon Optics
I have Yukon NVMT Night Vision Multitask 1x24mm Goggles and it turns on but when you look through the lens it is completely dark. How do I fix
4 Suggested Answers
SOURCE:
  • 15 Answers
SOURCE: i need fix night vision goggles
Check l that the HV is present at tube. If it is, suspect tube. If not, check the HV circuit - these vary, but most competent electronics trained technicans should be able to fault find on these.
Posted on Nov 29, 2008
  • 571 Answers
SOURCE: YUKON NVMT 3 ( 4X 50 )
'it does not have objective lens'?! Yes, it could be the reason why you cannot see anything. Your NVMT should have a lens in both ends. It's just a regular telescope with some extra features.
Posted on Oct 24, 2009
genious_eyez
  • 4 Answers
SOURCE: Yukon Ranger 5 x 42
there is nothing wrong with betteries.your Yukon night vision ranger 5x42 have problem with switching which is known as DSTA, not a worse problem,send your device to any reliable repairman who can fix it. thats all
Posted on Mar 07, 2012
Is VFR with night vision goggles at night dangerous for civilian pilots?
14 CFR 61.1 (b) (12) and (13) Definitions-Night vision goggles and operations. 14 CFR 61.31 (k) Additional training required for night vision goggle operations. 14 CFR 61.51 (k) Logging night vision goggle time. 14 CFR 61.57 (f) Night vision goggle operating experience. 14 CFR 61.57 (g) Night vision goggle proficiency check. 14 CFR 61.195 (k) Training for night vision goggle operations. 14 CFR 91.205 (h) Instrument and equipment requirements for night vision goggle operations.
Jan 04, 2017 | Aircrafts
Yukon Ranger 5 x 42 night vision goggles just stopped working, I put in new batteries, but when I press the ON button the on light, which is red, just flashes maybe 10 times and then all goes black. ???
Hello, let do this. IR illuminator has a montary switch, that is when you push it comes on, and when you release it the IR goes off and it has a red LED to indicate the IR illuminator is being activated.
When you turn you binocular on there will be a green LED activated. This switch is DTSA---double throw sing activated. That is, one throw of the switch it turns on the binocular, the throw will turn off the binocular.
Also within the control panel there is timing circuit to keep the IR illumniator on for ten second the shuts off. Make sure you have the right switches etc. Let me know, then we can brain storm on this matter. stewbison
Jan 29, 2011 | Yukon 28041 Binocular
The yukon NVMT 4 was turned ON and then flashed. Cover was on. Now the ON lights, IR Light works but visor is all grey and appear small lighting on bottom corner.
The scope may flicker or flash when used in a bright environment. To fix this you should only use a NVMT in a dark. It will restore itself in a few minutes or hours, depending on how long it has been exposed to light.
It may also flicker for the first several seconds of use in dark, before the device corrects itself.
With a severe exposure to bright light for prolonged time the light enhancing unit may damage beyond repair.
Oct 20, 2009 | Yukon NVMT (4x50) Monocular
Monocular has poor focus picture barely clear
Weak battery (below 2V). Lens cover on. Focus off (it can be adjusted). Too bright environment.
Without handling the scope myself these are the best guesses.
Oct 10, 2009 | Yukon NVMT 24022
Name of scope . Yukon . Problem : I tried to replace a battery in the dark. Removed the wrong part by relative force . Scope damaged. Two tubes on the front of the scope one is the battery tube and th
I would strip the wires as carefully as I could and get them back together, get the 2 AA batteries back in there, and see what happens. Then go about making a permanent splice in the wires and getting the lens to stay on there, or ship it back to Russia for repairs. Or find somebody to do it. I'm sure it can be done. Hope this helps.
May 24, 2009 | Zhumell Yukon NVRS Titanium 2.5x42 Night...
Yukon spartan my pic is not clear light works but cannot get focu
Define 'clear'.
Is it blurry? Focus the scope or clean the lenses.
Is it distorted? Don't know how to fix. Especially if the lens is cracked/scratched etc.
Is it dark/snowy? Put fresh batteries in.
Do you see black spots in the tube? Don't worry, certain amount of these are quite acceptable.
Anyway: It's a night vision for pete's sake. The picture won't ever be like the one on normal binoculars.
Jan 17, 2009 | Yukon 24021 Monocular
I need fix night vision goggles
Nov 27, 2008 | Optics
Sep 01, 2008 | Yukon NVMT (4x50) Monocular
Yukon night vision monolular 4x50 lense
Try to jank it left-right and simultaneously try to force it back to threads (either pulling or pushing). Don't hit it with anything since this may damage the insides.
Oct 10, 2007 | Yukon NVMT 20040WP Monocular
Focusing Yukon NVMT 20040WP Monocular
It should focus normally from some 50ft up. Try to adjust the dioptery on the rear ocular.
Mar 19, 2007 | Yukon NVMT 20040WP Monocular
Optics Logo
383 people viewed this question
Top Yukon Optics Experts
Marvin
Marvin
John Porter
Bill Boyd
Are you a Yukon Optic Expert? Answer questions, earn points and help others
