SOURCE: truck won't start. engine turns over. checked
have someone to stand back by the truck why you turn the key to listen to hear if there is noise coming from the gas tank if it is then its not the pump then it maybe your fuel pump relay or the crank sensor give these websites a try www.alldatadiy.com and www.autozone.com wish you the best of luck Michigan Man.
SOURCE: put new fuel pump, fuse, and relay in 1998 chevy
Did you check the ground wire on the frame. There is a ground wire that is bolted to the top frame rail near the left rear wheel opening. I've seen that wire break or get corroded where it bolts to the frame. I'm not sure of the location on a 1998 but that's where it is on the earlier models as well as the full size trucks. That wire also grounds the gas gauge, does the gas gauge read goofy? Also keep in mind the pump only runs for 3-5 seconds then it shut off, until the engine starts, or the starter is engaged. Good luck!
SOURCE: my 1998 chevy blazer fuel pump is not running, the
some times even though thy the fuel pump that is is bad you can git one or two more starts out of them by giving the gas tank a good jar-not so hard as to dent it .with key on you should hear the fuel pump start to run .if this is the case you will wont to replace it very soon
SOURCE: Where is the oil pump
It is more than likely inside of your oil pan. You will more than likely have to remove it. I would recommend an oil change while you doing this. I have a 2001 s10 crew cab, but I have never had to change the oil yet. Hope this helps!
Testimonial: "I am so happy that there are people in this field that are out there to help and answer questions. This site is very helpful..."
