SOURCE: why does the resistance on my elliptical randomly go to OFF while working out
Do this for your console Elliptical:Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replace the left and right disc shields and sideshields. Reattach the ends of the pedals to the crank axles
Good luck, sincerely. G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Hi Rachel, have you find a solution to the resistance problem with the m5? Thanks.
