Hello Rina;
My name is Peter. I am a retired field service technician.
You need to provide more information.
Upright freezers are very simple.
There is a label on the side wall witch has your model number on it.
1.) Locked in the defrost mode - If nothing is running except for the light being on then you are locked into defrost. Your defrost timer is in the back behind a metal plate. With a large flat head screw driver slowly turn the shaft clockwise one click at a time to turn the freezer on. If it turns on this component will have to be replaced.
Cost: $20.00
2.) Is your freezer cool? You may have a frozen drain and cooling coil. Un plug your freezer and leave the door open for 24 hours. After several hours check to see if you have water build up in the bottom of the freezer. If so, you are going to need to keep soaking up water unit there is no more.
3.) Can you hear the cooling fan running? These fans are $35-65.00.
4.) You may have a bad thermostat, bad defrost heater, or a refrigerant obstruction.
I need more information from you to determine the problem and the model number.
