Question about Hisense TA42P40M 42 in. Plasma Television
Need help to lighten the picture. Screen to dark to see the menu
Need help to do this with the remote
    Top Expert:
  • Hisense Master
  • 76,046 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Posted on Jun 24, 2015
SOURCE:
The picture can be seen but too dark to enjoy. What setting on the tv can be used to lighten it up? it is three years old and a westinghouse.
Go into the main setting menu which is accessed with the remote, there you will find the settings for the contrast and brightness, but if it just got dark chances are you have a failure and the settings will change nothing.
Mar 16, 2017 | Televison & Video
My tv screen is to dark how do I lighten the picture
If your TV has already fully adjusted in brightness set up?, and there will be no good picture results?...try to adjust the "SCREEN-Screw" at the flyback slowly. If the picture still dark'?. the picture tube has need to rejuvenate.
Oct 24, 2014 | JVC Televison & Video
Our Sony Tv RMyD003 screen is darker than we would like and we need to brighten the picture. We are unable to locate our Manuel and would need your help. Thank you
Try going to your menu or input select and you should see a scale to darken or lighten input. The remote should have a button on it to let you get to main menu.
Aug 11, 2013 | Sony RMyD003 Remote Control
Picture too dark on lcd hisense
get to the screen menu and alter the contrast to lighten up the screen. take it back to the repairer as it may be only be replaceable-not repairable.
May 11, 2013 | LG 42LC2D 42 in. LCD HDTV
Dark picture..not bright picture
The whole point of a webcam is to be able to see the person you are speaking with, and let them see you. When the image broadcasted by your camera is too dark, the person on the viewing end won't see anything but shadows and dark shapes. Learn how to brighten your webcam image so the people you chat with can see you.
Place lamps behind and to the side of the webcam. This casts a light on your face, but the lamps will not wash out the image because they are behind the camera. Turn off lamps that are behind you. You have trouble seeing things when you are looking in the direction of the sun or a light bulb. Your webcam has the same problems. Don't make it stare at a bright light. Open up a white screen on your computer to brighten your face. The white screen will create the brightest possible light from you computer screen and help lighten your webcam image. This option is best when lamps are not available. Open up an empty tab in your Internet browser, or a blank Notepad document, and expand it to the full of your screen. Adjust your webcam settings. The settings available to you will depend on your webcam, but many of them offer a "Brightness" setting that you can increase to lighten your webcam. Open the program that came with your webcam, then look for a "Settings" or "Options" menu. Increase the "Brightness" setting until it has lightened your webcam enough.
b>
Feb 08, 2013 | Gear Head Computers & Internet
Colors trail behind motion in picture...color too dark
replace T-con board ( top centre of lcd panel ) lvds cable plugs into this
Jun 06, 2009 | Sony BRAVIA KDL52XBR2 Television
The tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
May 27, 2009 | Toshiba 57H81 57" Rear Projection...
Hisense TA42P40M 42 in. Plasma Television Logo
44 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Paul
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
