Woods 59200 Lamp and Appliance Timer with Easy OnOff Settings 2Prong plu Logo
C
Casandra Fussell Posted on Jun 23, 2015
I have model # RLV1801 WHERE DOES THE SWITCH GO ON THE STAND
1helpful
Bike will crank but won't start
Difficult working blind on an unknown bike. But is probably related to either a broken side stand switch, or some type of inertia crash cut off as on cars with fuel injection.
year make model side stand switch
or
year make model inertia switch
Aug 26, 2021 • Motorcycles
Hyosung sense kick problems
Hyosung used a very bad quality side stand switch on some models. I just removed the switch located at the stand's pivot and short the leads to bypass the switch. Note that you are not protected by this safety feature any more and must be very careful not to ride with the stand down. It is not a big deal and you get used to checking that as you become a better rider.
Engine cuts out when put in 1st gear, ticks over ok in neutral
this often means there is a problem with one of the side stand safety switches, there is one activated by the stand, and some models also have another switch under the clutch lever
Having problem with the bake igniter not always igniting. Hear clicking, but no flame. Doesn't happen all the time.
You may have a weak igniter or a bad safety valve depending on the model. Let me explain. Their are many different types of oven valves. Some use glowbar and others use standing pilots, still others use a igniter with a safety valve and flame detecting switch. So you do not have a generic problem. To get a specific answer I will need the model number. Since you say you hear the clicking I am gonna assume that is a standing pilot with spark igniter nd safety valve/flame switch. In that case you either need to replace the valve if it is a combination one with thermocouple and valve all in one package or the flame detecting switch if your model has indeed a stand alone falme switch I have some repair photos: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2helpful
2answers
1993 bmw 1100 cutting out
sounds like there is a switch there, you should be able to see it. here is a link to free pdf service manual for your bike http://www.carlsalter.com/motorcycle-manuals.asp
On and off switch for hobart stand up mixer a200
I'm a hobart tech---what is the ml number on the data plate?
Lcd tv turns off after 5 mins, leave 2 mins comes on to stand by
Swollen ( bad ) caps in power supply first place to look.............T.
Top Woods Hardware & Accessories Experts
vince
NOEL
NOEL
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
