A damaged MDB file gives this message when i try to open it: The Microsoft jet database engine stopped the process because you and another user are attempting to change the same data at the same time. The message is obviously wrong, no other user is attempting nothing. I really want to repair this database as it contains customers data. Please tell me if and how can i repair this file. file Format - Access 2010.
First one apply short guide, second make use of http://www.mdb.openfiletool.com/ MDB Open File Tool
· Launch the Microsoft Access application, but do not try to open the corrupted MDB file.· Go to "Tools" in the top menu bar, expand the "Database Utilities" submenu and select the "Compact and Repair Database" option if you are using Access 2002 or 2003. If you are using Access 2007 or 2010, you can find the "Compact and Repair Database" option by clicking the Microsoft Office button and going to the "Manage" menu.· Highlight the MDB file that you want to restore and click the "Compact" button.· Enter a name for a new database file, which will contain the restored data from the damaged MDB file.· Navigate to the location on your hard drive where you want to save the restored version of the file.· Click the "Save" button. Access will now compact and repair the MDB file and save a restored version in the location you selected.
With Access File Recovery software, you can have improved file recovery flexibility than any other software of data recovery. You can perform recovery operation in all Access versions and get your database back. It is an intelligent solution to fix all corruption issues in ACCDB and MDB database files and saves all the deleted records and objects like indexes, queries, relations and tables, on new database. In addition, the software supports calculated data type and linked tables. It also recovers encrypted modules and forms and compatible to MS Access 2016 and other earlier models.
When it comes to crucial data. User need a reliable solution. Download the free Demo version of MS Access recovery tool to recover and preview your data. After this you can export the data using full version of this software. Access Recovery Tool Repair and Manage MDB or Accdb Database Files
When it comes to repair and recover the corrupt MDB database, this would be best if you use Access File Recovery Software which helps to recover the inaccessible or damaged MDB or ACCDB files. It is really a helpful tool which recovers the data in each situation
