Measuring Tools & Sensors Logo
Posted on Jul 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just brought a sperry dm-350A to test the switches on my dryer I thought they would come with instructions on how to use it but it didn't. Is there a place where I can go and learn what the symbols stand for?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
10163
Points
21
Just got mine from home depot. Stick the black wire into the COM port and the red wire in the V port on the right. The red wire is the positive and the black is the ground. Touch the red tip to the positive and the black one to a ground. Turn the dial clockwise to the right and you are measuring your voltage(i left it on 200).
  • Amquietone Oct 01, 2010
    Thank You guys so much! Was having the same issue with instructions and was going to use this unit for checking my dryer! You guys are lifesavers!!!
Anonymous
Level 2:
  • Expert 308 Answers
  • Posted on Jul 17, 2009
Anonymous
Expert
Level 2:
Answers
308
Questions
Helped
152343
Points
748
Anonymous
Level 1:
New Friend:
  • Posted on Jan 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
10163
Points
The instructions for the DM-350A can be downloaded from SperryInstruments.com. I downloaded mine and the instructions ****, but maybe they will be more helpful to you.
I have a new DM 4100 by Sperry and can't get the back open to change the battery....It is stuck or I don't know what I'm doing.. Jim
1. Disconnect the test leads from any energized circuit and then from the instrument.
2. Turn the range switch to the "OFF" position
3. Slide off the back case battery cover.
4. Remove the battery from the compartment and unsnap the battery connector.
5. Replace the battery with a 9V transistor type battery (NEDA # 1604), For maximum battery life, alkaline cells are recommended.
6. Reverse the above procedure to complete replacement.
How to use a sperry dm-210a multimeter
Hello Anthony, I sent you a link so you can find out the manual of the tester Sperry DM-210a and another where you get an explanation of the operation
I hope you can solve your concern
Greetings Franco Dosil
Hola Anthony, te envio un link para que puedas descrgar el manual del tester Sperry DM-210a y otro donde te dan una explicacion del funcionamiento
Espero que puedas resolver tu inquietud
Saludos Franco Dosil
https://www.hunker.com/13414165/how-to-use-a-sperry-dm-210a-meter
https://greenlee-cdn.ebizcdn.com/media/52058078REV01.pdf
https://www.hunker.com/13407450/instructions-for-a-sperry-dm-210a
How and where do you install the battery into the sperry- 6400 multimeter?
Refer to instructions that came with meter, it is there. If you threw away instructions here is a big hint.
https://www.manualslib.com/manual/1346232/Sperry-Instruments-Dm6450.html?page=6#manual
How do I know if I have continuity on my Sperry dsa 500
Set the knob to the ~600V position. With the power on/connected, place one test lead on one side of the fuse and the other test lead on the other side of the fuse. Be careful not to touch anything with your hand or you will get shocked. If you read voltage the fuse is bad. If you don't read voltage the fuse is bad.
Alternately you could DIS-connect power remove the fuse and test the fuse for OHMs, which on your meter is the last icon with the ((((.
It will beep and/or read very low ohms <5.
Here's the manual -
Sperry Instruments DSA 500 Operating Instructions
Changed battery on Sperry DM-5300 and now it will not power up
Try it again, with a new, tested battery.
You likely installed a "dud" (or put it in backwards?)
1helpful
Volt meter
If you've never used a volmeter,Google it.There is a lot of info for free.
13helpful
Does the Sperry DM-350A test for continuity? I can't seem to find a setting that works.
yes. But you have to change the LEADS down below. One must connect into the Omega connection at the bottom (looks like an upside down horseshoe). And the meter setting is where the arrow (?) symbol is. Touch the two leads together and it should "zero out". Now you're ready to check continuity.
1helpful
Checking batteries
I assume a "DM-350a" is some kind of a digital multimeter. I Googled and found it might be a "A.W. Sperry DM350A 5 Function 17 Range Digital Multimeter" and looking at the ranges available on that meter, you can't really thest the battery "under load" the only reasonable way to test small batteries. the DC current only goes up to 200 milli amperes. A "C" or "D" size flashlight battery puts out 1 to 4 amps depending on conditions. That's 5 to 20 times the current readable by that meter. The volts on one of those batteries is probably 1.6 volts to 1.3 volts etc. If you live in the United States, I'd say go to Radio Shack and spend $5 to $15 and buy a battery tester like "Enercell Analog 9-Range Battery Checker, $14.99, Model 22-156, catalog # 22-156"
Then you and anyone in your family can read the instructions and test 8 or 9 different type batteries. Battery types: 1.5V button-cells, "AAA"/"N"/"AA"/"C"/"D", 6V, 9V, 12V, 15V and 22.5V..
This is not supposed to be an advertizement, and I have no interest in RadioShack,... but it's supposed to be instructional.
Small price, Good instruction to anyone who can read, and if anyone forgets, they can re-read. Testing a lot of batteries in a sitting goes very fast with these.
Differently, with the sperry, or any voltmeter, you'd have to select a resistor small enough to draw the current, and large enough not to overheat or burn, connect it and measure the loaded voltage drop, compare the voltage and current of the loaded battery, and compare it to that of a new battery, and a battery you might consider too weak for your application.. Voltage equals amps times resistance, and power equals amps squared times resistance... Really, buy a battery tester.
Regards --- GooseBay_Camper
1helpful
Checking batteries AA D cel with a sperry DM 350A digital multimeter
dc .... no lower then the voltage range of the highest voltage of the battery.
Measuring mA with a DMM
The most obvious solution to your problem is that you may have the meter simply connected backwards. To make life easy, Groovetubes sells a thing called a bias probe that makes biasing tube amps a breeze.
Top Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
