GE Zoneline In Wall Ptac Unit Air Conditioner 9300 Btu - Cooling And Heating Logo
James Ballins Posted on Jun 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is the unit supposed to cycle cold air. For instance it blows out room temperature air for 30 min then blows out cold for 10 min.
william simpson
Level 3:
Genius:
  • GE Master 1,363 Answers
  • Posted on Aug 10, 2015
william simpson
GE Master
Level 3:
Genius:
Answers
1363
Questions
14
Helped
318166
Points
1636
It depends on thermostat setting. compressor might be going off on a safety.
3 Related Answers
Anonymous
  • 54 Answers
  • Posted on Jun 08, 2008
SOURCE: Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
flatech
Michael McQuay
  • 111 Answers
  • Posted on Oct 27, 2009
SOURCE: I have two ptac units, both want to run 5 or 6 mins. and cut off
Make sure there is nothing in front of the units, Chair, Couch ect, if you take the cover off the Units, you will see a little black Thermoster attached to the coil.
If the air bounces back off of something then it will cool that Thermoster and shut the unit down before the desired room temp is acualy reached.
Also make sure your Thermastat control knob is turned far enough to the right so that its asking for more cooling, Or desired temp.
Hope this helps.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Anonymous
  • 832 Answers
  • Posted on Jan 06, 2010
SOURCE: 230/208 Volt Built-In Room Air Heat/Cool Unit
To locate the fuse;
1. Turn the power off or unplug the Room Air Heat/Cool unit.
2.Follow the power cord of the unit. This will normally
terminate at the fuse terminal/power reset button., where you can replace the fuse.
3. After the fuse/power reset button terminal the wire
go to a thermostat normally located at the air output
section at the front portion before it goes to the motor
and heating element, while the other wire may connect direct from the fuse terminal to the motor or
heating element.
This is just the basic electrical set up, it can be modi-
fied. Hope this will guide you in locating the fuse and
the thermostat.
fied
How do i get my newair af 1200e portable air conditioner to stop blowing cold and warm air.
that is normal operation when thermostat setting is reached it will cycle off compressor.
1helpful
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
1helpful
Convair instructions
Maybe that 30 degrees you are seeing is the room temp
I have recently installed 1Te Voltas 2 star A.C. I need clarification on the following 1) In cool mode, what is system of auto cut. Suppose I put on remove temp 27deg C. Temp of the room goes up to 26 deg...
Dear Mahesh
In Cool Mode
Temp Diff - + - 1 deg C in Room Temp & Set Temp
This is auto cut
In Dry Mode
Comp Runs for 10 mins then get off for 5 mins then again get on for 10 mins this cycle continuues.
4answers
Frigidare window air conditioner with remote control about 3 yrs old. All controls seem to be working except when the energy saver mode is suppose to shut down the unit / the display goes dark but the...
Hello, I can assist you.
If the unit is supposed to turn off and it doesn't, it will be necessary to check several things.
  • First, is the unit cooling properly? See the section entitled "The air is cool but doesn't seem cold enough."
  • Next, is the temperature of the room adequately cool? If the room temperature is cold enough try setting the thermostat to a higher temperature. If the unit then seems to work properly leave the thermostat set to the higher temperature.
  • If the unit is cooling properly when it is turned on and the room is not cool enough the problem is probably that the unit is trying to cool an area that is too large for its capacity. Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
If the room size is too big for the air conditioner you have two possible choices. Either decrease the room size by shutting some doors or partitioning off an area of the room. Or, increase the BTU of the air conditioner for that room by installing a different air conditioner with a higher BTU rating.
4helpful
3answers
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
1helpful
2answers
My air handler comes on ,not the outside unit when my thermostat is in the off position even if i turn the thermostat down to 50 and have it turned off the air handler comes on for about 5 to 10 minutes...
If you have a standard thermostat the fan switch is for the air handler only. It completely over rides the thermostat for most settings. Now lets see this is what I'd expect:
fan switch on Indoor fan runs all time
Fan switch auto Indoor fan only runs when thermostat is set to cool or heat and the thermostat is turned up above room temp for heat or below room temp for cooling. In both of these modes the furnace blower comes on and stays on til the room temperature is satisfied. The outdoor unit only comes on for AC the out door unit will not come on for heat or the "on" setting on the thermostat. See exception 1 & 2 below...
Exception 1- (in a heat pump the out door unit runs in both heat and cool mode unless it has emergency heat turned on then it will not come on outside in the heat mode, and depending on the type of heat pump and furnace or air handler it is). A heat pump thermostat usually has "backup heat" and an "emergency heat" setting switch on the thermostat.
Exception 2 - On some thermostats they are made to cycle on the heat if the temperature reaches a preset temp (around 50'f usually but definitely by 40'f). This mode prevents freezing when if instance the homeowner is away or while the home is under construction. In this mode the fan inside can run but the heat usually comes on with it.
Exception3 - On some electric furnaces the heating strips may be individually controlled and thus not all come on at one time. This may give the feel of no heat especially if the room is cold.
Now there may be other exceptions but Ive tried to give you a heads up on some of the most common ones.
If you need more help please post more specifics about your unit/system as to for sure what switches are set to what setting and what is happening with each. My first though was that maybe your system is OK and you needed to know if the thermostat was working properly.
If this helpd you understand your problem would you please give me as hifgh a mark as you can. Thnaks for using fixya and good luck.
2answers
Carrier 42G250CF-1 won't blow cold air (on lamp flashes)
sounds like you low on freon, you will need a qualified tech to refill the freon.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Amana PTH153B35AK
This often happens if the unit is oversized or to close to a wall or object.
Top GE Heating & Cooling Experts
vince
Alfredo Texmenistan
Level 1 Expert
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
