Message VENTILATE will not clear. I can squirt an entire tank of water through just fine. In test mode I can activate the brew unit, grind and put water though the brew unit. but when I turned it on the ventilate message still appears. We decalcified.
VENTILATE ERROR at 27,211 brew cycles on 12/31/22. I read that a stuck Flow Meter might be the cause of the error. A Factory Reset was suggested, so I did that and the Ventilate Error cleared, but it returned on the 1st brew cycle. Since the pump works fine and I had nothing to lose, I continued Ventilating and let the water tank empty, so it really needed to Ventilate. Started with 1 liter of the hottest tap water available, I allowed the tank to empty and then Ventilated using 1.5 liters of boiling water. The Flow Meter must have cleared because I was offered Hot Water or Steam. In the end, the machine is working fine. I had to re-program all of the settings because of the Factory Reset, but my machine lives on. 2023 here we come.
Yes,the flowmeter is the problem!!!
