What does error code 0010 mean on Yamaha av receiver Rx-v773
- Firmware update doesn't start or doesn't complete
? Receiver doesn't power up after the update.
? Error message appeared when confirming the firmware version.
Recovery method using USB method:
1. Unplug the AC power cable from wall outlet.
2. Insert the USB thumb drive which has the firmware data stored inside, into the USB port located on the front panel.
3. Press and hold the INFO key and keep it pressed while you plug the AC power cable back into the wall outlet again.
" USB UPDATE " will appear on the front display. Then, release the INFO key.
4. The update will start automatically.
5. When " UPDATE SUCCESS " appears on the display, firmware update is completed.
Power off the receiver and remove the USB thumb drive.
6. Confirm updated firmware version.
- Error message appeared during the update
Cause: For some reason, the receiver can't read the firmware data.
Method: For your solution, check the following
[Update through Internet]
? Check Internet connection.
Check if the Internet connection is working by playing an Internet radio station.
(See owner's manual for details)
[Update by USB thumb drive]
? USB thumb drive is connected properly to the receiver.
? USB thumb drive is not password protected.
(AV receiver cannot read data from a security protected USB thumb drive)
? Make sure the USB thumb drive is inserted before the receiver is powered on for the update.
? The firmware data is stored in the root directory of the USB thumb drive.
? There is no other data except the firmware data in the USB thumb drive.
? No folders are created in the USB thumb drive.
Else, retry the update by USB using another USB thumb drive.
