Fisher and Paykel GWL11 Top Load Washer Logo
m
mike barry Posted on Jun 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is fault code 130 and how do I fixit? - Fisher and Paykel GWL11 Top Load Washer
Paul P
Level 2:
Filmmaker:
Uploaded 5 video answers.
Scholar:
  • Fisher and P... Expert 80 Answers
  • Posted on Jun 22, 2015
Paul P
Level 2:
Filmmaker:
Scholar:
Answers
80
Questions
0
Helped
61359
Points
218
130 indicates a faulty Rotor Position Sensor (RPS) or a bad connection to the RPS. This can be a common fault on all Smart Drives. Rather than explain the the procedure you can watch this video which a kiwi guy has done on how to fix it if you are good with that sort of thing. IF you live in NZ the best deal to get a new RPS is Rotorua Appliances or search TradeMe for RPS. To watch the video click the link. Good luck https://www.youtube.com/watch?v=6FQc64aBzc0 Fisher and Paykel 130 10000010 Error Code Fix
  • Anonymous Jul 05, 2015
    Awsome Mate. Thanks $96.00 worth
  • Paul P Aug 08, 2015
    F**K $96 bucks for a RPS?????!!!! Where from? They should cost around $30 to buy
1 Related Answer
Anonymous
  • 34 Answers
  • Posted on Aug 22, 2009
SOURCE: Fault code 130
rotary position sensor fault. underneath the machine. Unbolt plastic cover with 16mm socket all of the plastic will come off. Undo four 10mm bolts around shaft. Pull off the big round thingy with cooper wire on it carefully. The purple wire is connected to the sensor which looks like a computer card and fits between the copper things ,pull up the sensor carefully and unpug the connection clean off the blue stuff on contacts,use electrical spray cleaner. Put back together in reverse.
Comments: Aug 03, 2009 - if it still doesnt work reset the machine by turning it off at the wall and waiting 2mins and start again. If that doesnt work the sensor may need replacing.
Hi Dear My washing machine Fisherpaykel got faults codes 130 what would I do ?
130 is a sensor fault on the main drive motor. I'm not sure if you can purchase this or if you have to get the complete motor.
What do fault code 130:02 130:04 130:07 130:14
u need the servicebook with the codes in it could be any number of items
2helpful
2answers
Fault code 130
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor Position Sensor.
Likely causes of this fault are a bad connection on the harness between the Rotor Position Sensor and the Motor Control Module,
or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted.
Vw passat 2002 diesel 130bhp fault code 462D whats the fault and what is needed to fixit
This free Android Renault fault code lookup app has these codes https://play.google.com/store/apps/details?id=com.zorac.obd
2helpful
I have a fault code on off off off off off on on
That is fault code 131
131. (10000011) Phase 1 to 6 - Repetitive Rotor Position
Sensor Error
This fault is similar to fault number 130 above but differs slightly in that
it is a continuous condition. See fault 130 for service procedure.
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
from the Rotor Position Sensor. Likely causes of this fault are a bad
Motor Control Module, or a faulty Rotor Position Sensor.
Action: 1. Check for corrosion on the edge connector of
2. Check the contacts on the rotor positional
sensor end of the hall harness to see if any
have been damaged. (Each set of contacts in
the socket has two wipers. If the distance
between these wipers varies between
different contacts, replace the rotor positional
sensor harness.)
Fisher Paykel GWL11 fault code 130
its really important the R.P.S you replaced is correctly fitted so double check it,also the connecting block if corroded in anyway will cause the faulty its easy to see the bluey color of corrosion, i have struck faulty new sensors beforebut not all thst common if you are really sure all that is 100% then it can only be the wiring loom
3helpful
My fisher & paykel 1w812 keeps coming up with a 130 fault code , any ideas
The 130 code means you have a Single Rotor Position Sensor Error.
Washer will not spin there is water on the floor and has a fault code of 130 it is fisher+paykel brand model numberWL26CW1
Hi just read your posting.Error Code 130 means your fault is called Single Rotor Position Sensor Error.This component is attached to your motor which is underneath your machine.What concerns me is your machine is leaking.Did the Error Code appear the same time your machine started leaking?The reason I am asking this is because the water could have damaged the rotor sensor.Is the water leaking underneath the machine?Please reply with additional information and I can help you rectify this fault.
2helpful
Fisher & Paykel Washing Machine IWL12
130 rotary position switch fault 136 motor fault
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
