Hello experts, here im using Microsoft outlook for mails while i am formatting my system i took a backup .pst file and now after configuration now while i import .pst file to my outlook it says an Error report Given Outlook.pst is not a personal folders file i used third party software to repair my pst backup and changed read write options none solved my problem Help!
Try ZOOK PST to PDF Converter is the amazing solution to convert PST to PDF with attachments and other data items. It easily extracts Outlook PST emails and saves PST to PDF format along with their entire data items such as Outlook emails, contacts, calendar entries, notes, tasks, and much more. All the Outlook data will remain saved in same folders and sub-folders even after performing the conversion process. the tool can easily support all the versions of Outlook i.e. Outlook 2016, 2013, 2010, 2007, and all below versions to provide the unbeaten conversion of Outlook PST to PDF. The tool can also provide its trial edition to users to check the working of the utility. It offers user to migrate 25 items from Outlook PST to Adobe PDF format for checking the tool.
Explore More: https://www.zooksoftware.com/pst-to-pdf/
Try the most professional Cigati PST Recovery Tool to repair and recover corrupt or damaged Outlook PST files without any data loss.
Visit Site: https://www.cigatisolutions.com/outlook-email-recovery/
The best method to repair PST corrupt files is to use the PST repair tool. With the help of PST repair tool, you can easily repair the corrupted, damaged and break PST files. It can save you time. It can also save the files in different formats.
For more info:- https://www.shdatarescue.com/pst-repair/
The best way to recover the corrupted Outlook PST files!
Use the new Outlook PST repair tool and repair all the corrupted PST files in less than a minute. The tool supports the import or export of Outlook PST mailboxes to Mac Mail. Plus it is compatible with all the Outlook and Windows versions. For more info visit-
http://www.howtomergepstfiles.com/repair-pst-file.html
Hi, christosperis
I already faced this issue and I got panicked at that time. I tried the inbox repair tool that comes with MS outlook but got no luck. So, I came to know about third party PST Repair Tool that can repair any corruption error in PST file. It's good that you backup your PST file before formatting. You can also try the inbox repair tool as some people say this tool works on minor corruption.
If your files still not recovered then I would suggest you use DataRecovo PST Recovery Tool that works super fast on corrupted PST file and somehow you can't able to recover your file then you can also take help from their support. This software also ensures a full refund policy if this tool doesn't help you. So, it's a safe and one-time investment as it comes with a lifetime warranty.
It also comes with a completely free (demo version) that you can try to check as even this free version can able to recover your 25 emails per folder.
Outlook PST Repair Software
If you want to recover your PST file then follow these steps:
1)Go to the control panel
2)Click mail>data files.
3)Locate the repaired PST file from the list, select the file and click the option. 'set as default"
4)Close all window and open the your outlook application, Now 5)you can access all recovered mail items.
If you are facing this issue and want to find a solution, then i will recommend you to try Outlook PST Repair tool this software will help you recover corrupt and inaccassible PST files into various format like EML, RTF, MBOX, IMAP, MHTML, PDF, PST, MSG, TXT, DBX, and HTML without facing any issues. It is easy to use tool to recover PST data.
You can download this software from here - https://www.downloadtopten.com/recovery/pst/
You can edit read / write permissions of PST file by right clicking on .pst file and then select Properties then click on Security tab and then you will see edit button. by clicking on Edit button you can edit permissions of .pst file. Allow full control to your user account here. But you can do this by logging in as an Administrator of Computer.
If this solution doesn't work then you have to go for another trusted third party tools. You can try SysTools Outlook Recovery or PCVITA Outlook Recovery or RecoveryTools MS Outlook recovery.
Best available application in the market to recover emails or other Outlook item from corrupt PST file.
Go through: Outlook PST Recovery
Don't worry, Some days before I did also lost my PST file but after using Kernel for Outlook PST Repair Software I recover every file and folder easily. For better and secure solution you can also run this third party software.
Try these; Hopefully your third party software or you created a backup before trying to repair the files.
Repair Outlook Data Files pst and ost
