Fuel slow stops after running engine for a short period
Check fuel filter
Testimonial: "Changing the fuel filter delayed the problem. The fuel tank cap appears to be the problem. Thanks for your help."
Try changing the fuel line as there has been a few cases where the inter liner of the fuel line on the carb complaint systems collapsing causing this problem.
Also check fuel cap rubber seal if it has deteriorated and parts of it may be blocking fuel flow from the tank. An additional thing to try is leave the ful cap loose to if it is venting problem.
Loosening the gas cap did help. Will try running it longer this way. Thanks.
I've changed the fuel lines from the tank to the fuel pump. The fuel pump is new as is the fuel filter. The gas cap seems suspect as the engine stalling quit when I loosened the cap. Caps not sold in Wichita. Will order one and try it out. Thanks...John
