Plugged it in and it say's bucket Full and will not shut off the water full and there is not Even a drop of water in bucket
SOURCE: shuts off-"full" light when it isn't
Hi, I'm not familiar with your model but there is usually a plastic rod sticking down from the "roof" of the place where the bucket goes, and this is pushed up by the floating part of the bucket.As the bucket gets full, the float pushes up on the rod which activates the microswitch to turn of the compressor.
With me so far? OK, it could be that the rod is stuck in the "up" position and needs to be pulled down so the microswitch can go to the normal working position.
There is likely to be another mechanism which prevents the compressor running when the bucket is absent, or maybe they are combined on your model. Check that little rod and find out if it moves as it should.
Hope this helps. If this "fixes ya", I'd appreciate a rating for my reply, If not, please delay the rating and add a comment with any extra info you have and I will try to think of something else.
Cheers, D.
SOURCE: I need a new bucket to collect water in a Maytag
if you still have that piece you can glue it back in place. just go to any hardware store and have a clerk assist you in getting the right adhesive.
SOURCE: the bucket is empty, but when I plug it the full
I thnk your tank is askew. Adjust the osition of the tank until the light goes off ...
SOURCE: Maytag Dehumidifier will not run. Indicator light says "full"
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
SOURCE: My Maytag Model M7DH45B2A REV-A will not turn on. The full light
It's unbalanced .Give it a swat
There
are many reasons why a dehumidifier will not work or collect water.
Here
is a tip that I wrote to help people to figure out what is going
wrong with their dehumidifier
Dehumidifier
is running but no water is in bucket
heatman101
