1.Press MENU
to see the menu.
2.Press VOL+ or
VOL- to highlight SET.
3.Press CH+ or CH-
to select PARENTAL CONTROL.
4.Press VOL+ or
VOL- to see the SECRET CODE screen.
5.Press the Number buttons
to enter your four-digit secret code.
[The code will appear on
the screen as you enter it. The code "0000" is the default
of the
TV. If you have not set up
a code previously, then "0000" is the code.You cannot use
"0000" after you set your own code (unless you reset the code to
"0000").]
6.Press CH+ or CH-
to select MASTER ENABLE, BLOCK UNRATED,or BLOCK NO
RATING.
MASTER ENABLE: This
is the "master switch" for Parental Control. When ON, all
blocking/censoring is enabled.When OFF, all blocking/censoring
is disabled.
BLOCK NO RATING: All programming with NO content
advisory can be blocked if this feature is ON and MASTER ENABLE is
ON.
BLOCK UNRATED: All unrated programs (based on Movie Ratings or TV Ratings) will be blocked
if this feature is ON and MASTER ENABLE is ON.
7.Press VOL+ or
VOL- to turn the blocking option ON or OFF.
8.Press TV/AV/EXIT
to remove the menu from the screen.
ok
