Question about Lowrance Elite 5 Color SonarGPS Combo
How do you manually reset a lowrance eliite 5
It turns on and does not go past the lowrance page and will not turn off
    Scholar:
    New Friend:
  • 97 Answers
You can try holding in the zoom in/out buttons (+/-) as you push and release the power button.
Hold the zoom keys until you hear a beep.
If your hard restart is successful. You should see the GPS screen with prompts for language etc.
if you cannot get the system to cooperate and all you see is the "Lowrance" screen, then you are experiencing a Castro pic system failure and the unit needs to go back to Lowrance.
Posted on Jun 21, 2015
SOURCE:
Need owners manual for lowrance model# elite 4 hdi
here you go
[PDF]Mark-4 HDI & Elite-4 HDI - Lowrance
https://www.lowrance.com/.../Lowrance.../ELITE-4_HDI_OM_EN_988-10576-001_w....
Installation & Operation manual. Mark-4 HDI & Elite-4 HDI. Operation manual ... Lowrance Mark-4 & Elite-4 HDI ...... Selects the transducer model attached.
[PDF]Elite-4x HDI - Lowrance
www.lowrance.com/.../Lowrance.../ELITE-4X_HDI_OM_EN_988-10586-001_w.pdf Installation & Operation manual. Elite-4x HDI. Operation manual .... 4. Basic Operation ' Elite-4x HDI. Selecting Pages. To select a page, press the keypad in the direction of the desired page and ..... Selects the transducer model attached to ...
[PDF]Mark-4, Elite-4,5, 7,9 Operation Manual - Lowrance
https://www.lowrance.com/.../Lowrance.../MARK_ELITE_SERIES_CHIRP_OM_EN_98...
... Elite-7 & Elite-9. Operation manual ... NOTE:This manual covers Mark-4, Elite-4, Elite-5, Elite-7 and Elite-9 units. As a result ..... Selects the type of transducer model attached to your unit. ..... HDI 83/200kHz (Medium/High CHIRP. 83/200kHz ...
manual for lowrance model elite 4 hdi Google Search
Oct 21, 2017 | Lowrance Boating
When turning on the Lowrance the depth indicator will only register 0.0 and continues flashing the number. The Lowrance is a LCX-17M. We tryed the Lowrance on another boat with a working transducer...
here is the link to your the lowrance web site. the trouble shooting guide says that if you tried to it on another boat than you might need to take it in for service. but there is a section that explains how to do a soft reset on the unit. you might try that.
http://www.lowrance.com/en/Support/Troubleshooting-Guide/Depth-Reading/
please rate and comment on your experiance with fixya.
Aug 15, 2008 | Lowrance LCX-18C
My Lowrance 5500c powers up gets to aquired satelites and then stops on that page.No buttons work and the power has to be disconnected to turn off.
It is an old unit, it has been discontinued, there are no software updates for it.
Technology has moved on with larger High Definition displays, colour and side imaging. Time to retire it and look at Humminbird. I have the 998 HD Si. That replaced a 798 before it. Lowrance have the Chirp equivalents if you want to stick with Lowrance.
Or you could return it and see if they can fix it
http://www.lowrance.com/en-US/Products/Chartplotter/GlobalMap-5500C.aspx
I did find your manual :>)
http://www.lowrance.com/Root/Lowrance-Documents/GlobalMap5500C_0151-271_012105.pdf
Oct 03, 2016 | Lowrance GlobalMap GPS
How do I turn on fish alarm on hds5x lowrance fish finder
If you turn on the "fish I.D. mode" in your sonar options then you will be able to turn on the fish alarm as well. Lowrance HDS 5x Gen2 Fishfinder
This a link to a pic file for your owners manual.
Go to page 67 to, see how to access and enable/disable alarms for your unit.
Nov 30, 2014 | Lowrance HDS5x Fishfinders
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
LOWRANCE HDS7 WHEN I TURN ON THE UNIT THE LOWRANCE "SEIZE THE DAY"
I can help with geofenced lowrance chartplotters and remove unlock and add language pack. Only gen3 and carbon
skype : denisthegreatest
telegram: @denveronly
Oct 01, 2012 | Lowrance HDS-8 GPS Receiver
I turn my power source on and my screen flashes like it's not reading anything from my transducer but the transducer is new.
Has this unit worked in the past, or are the transducer and the unit itself new? Is this a Lowrance LMS-240 as indicated before your question?
Please let me know and I can help you out here.
Thanks, just reply here,
Tim
Oct 31, 2010 | Lowrance LMS-240 GPS Receiver
Lowrance AirMap 600C won't lock on satellites
Reset the AirMap 600:
1. Turn unit off
2. Press and hold PAGES and PWR until you get the "warning, do not rely..." message and then release the buttons.
If it still won't acquire position, install the latest update from http://www.lowrance.com/en/Products/Aviation/AirMap-600C/Downloads/AirMap-600C-Software-Update/.
If it still won't acquire, and it has a clear, unobstructed view of the sky, and the batteries are good, there is a malfunction and it will require service or replacement.
Jul 13, 2009 | Lowrance Iway 500c GPS Receiver
Cannot access main menu or pages screen
I think I can help with your issue. I have an LMS 334c and have had a few issues in the past. Called the factory (this answer is not listed any where in your manual) and they instructed me to "Soft Re Boot" my unit and it would put everything back to factory settings. Try this anytime it does not respond for whatever reason.
Turn the unit off.
At the same time press the Pages and Power button. Hold both down until you see the square box come up in the screen. You should have your factory settings again. May need to try a few times.
Lowrance said it works just like a computer, ever now and then it just tries to disect to much information at one time and hangs up.
Good luck. James Cantwell
Nov 03, 2008 | Lowrance LMS-330C GPS Receiver
I have a iway 250 and don't know how to put in destination
Copy & paste the URL, I have provided below, to your web browser & take will take you to Lowrance's manual download page. You'll find the !way 250C listed there.
Good luck.
http://www.lowrance.com/Downloads/Manuals/
Feb 29, 2008 | GPS
Lowrance Elite 5 Color SonarGPS Combo Logo
1,617 people viewed this question
Top Lowrance Boating Experts
Bob Peloquin
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
