Question about Yes Audio Players & Recorders
My TRIO Media Player has been frozen for 3 days it freezes while on startup it cant even come on Help me I cant go without my TRIO And yes Ive token out my battery Can some help me?THANK YOU!
SOURCE:
SOURCE: Rio Karma freezing on startup. wont connect to computer.
WoW! thanks a million, I had tried everything to fix my wifes RIO and nothing worked! hitting it actually solved the problem!!!!
Posted on Dec 16, 2007
SOURCE: personal media player
no drivers and player na recognized.
Posted on Sep 06, 2008
  • 563 Answers
SOURCE: i need help with my coby/media player for vista
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
You don't need to use Windows Media Player in order to put music on your player. There are various reasons why it may not be syncing. Below are instructions for how to put music on the player using copy and paste. It's the easiest way to add music to any regular MP3 player.
How to load an MP3 player without using Windows Media Player. First, allow me to clarify a few things so that there is less confusion: When you connect an mp3 player to a computer, you will not be able to use it until it's disconnected. In other words, the only thing you should do while the player is plugged into the computer is adding or deleting files. You can't use the buttons on the player while it's communicating with the computer, and as long as it's connected to the USB port, it's communicating. Ok, let's get started! Step 1 Connect the player to your USB port using the cable that came with it. (NOTE): If the player has a male USB connector already on it, connect the player directly into the computer without using the cable. In other words, only use a cable if you have to. Step 2 Click the "Start" button or press the key on the keyboard that has the Windows logo, and go to My Computer (Windows XP) or Computer (Vista). Step 3 Locate your MP3 player on this screen. Do not close this window; just minimize it. (NOTE): It should show up under Devices with Removable Storage or as a device under "Other." Most importantly, it should show up on this screen as something! When the player is connected, you should have something on this screen (usually an icon of some sort) that represents the player. This lets you know that the unit is ready to receive files because it's being recognized by your computer. Step 4 Locate and open the folder that contains your music files. Step 5 Using the mouse, copy one or more files. (Right mouse click on file, then left mouse click on copy) Step 6 Go back to the "My Computer" or "Computer" screen, right mouse click on the icon representing the player and left mouse click on paste. You should see a small status bar appear showing the file(s) being copied from your music folder to the player. Step 7 Click on the Safe to Remove icon found in your system tray and disconnect the player. And that's it! If you need additional assistance, I will help in any way that I can.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Posted on Feb 06, 2009
christykraj
  • 107 Answers
SOURCE: frozen
Please try to reset the player and see whether it helps.
This could be done by inserting a paper clip into the reset hole and press and hold for about 20 seconds. This should unfreeze the player.
All the best!
Posted on Jul 28, 2009
pabloloco
  • 2335 Answers
SOURCE: the pearl logo appears but its not reognizd by any pc!!why!!
When my Pearl stopped working, I was able to reflash the firmware even though the computer couldn't recognize it when I plugged it in. I would run this from a PC not a MAC if possible, as I haven't tried it on a MAC.
Get the pc software here:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/2243/related/1
Follow all the instructions that popup when you run the software and you should be fine.
Posted on Sep 18, 2009
How do you take the back off of a touch screen Trio T300 model portable media player
You cant. SO DONT. There is a small hole at the bottom of the device. Use a pin needle or even the stylus to reset the machine.
Oct 26, 2011 | Mach Speed Trio Portable MP3 Player
My screen on my trio t3000 is frozen. how do i un freeze the screen
I just clicked the reset button on the side with the back of my earing for three seconds and the screen went black, so I powered it on, and now everything is fine. Try that :)
Dec 25, 2010 | Mach Speed T3000 MP3 Player
Frozen
All the best!
Jul 28, 2009 | RCA Pearl TH1102 MP3 Player
Game freezes
Your disc could have a scratch or your Eye Reader in your XBOX is bad. Same thing for me on Oblivion i walk in an area and BOOM my disc freezes
Jun 14, 2009 | Bethesda Softworks Fallout 3 for Xbox 360
Newly purchased philips gogear (frozen)
Go to Philips website and update the firmware to resolve most freezing issues (as long as they are not hardware-related).
Feb 23, 2009 | Philips GOGEAR SA6045 MP3 Player
Cant download music from windows media to mp3 player
do not open window media ....go to my computer...open the folder that has all of mp3 files (on pc)...now plug up your mp3 player....go to start/ my computer (yes another window)/do you see a new icon/drive (it should be the mp3)...open it.....now resize both windows so that they side by side (or top & bottom)..now click & drag (or copy and paste) all the songs you want from pc folder to the mp3 .....once you are finish do not .........do not just unplug the mp3 player....go to the task bar (your lower left) and look to safely remove this device....hope this help....have fun
Dec 29, 2008 | GPX ML848B Digital Media Player
MP3 PLAYER NOT WORKING SCREEN FROZEN IN INITIALIZING
I need help...it's a Christmas gift and i cant get my daughters hello kitty digital photo frame / mp3 player to un freeze.It wont turn off.
Nov 15, 2008 | Audio Players & Recorders
Freezing Microphoto on Startup and not recognized by computer
Happened to me too :(
I guess there is nothing we can do, the HD is dead.
I think i'll sell the battery and buy a new one.
Sorry....
Jul 11, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Frozen iriver x20
If your player freezes on "Building Library" (usually a result of putting certain type of .m3u playlists or too big images in id3 tag):
1. Turn the player off - you may need to take the battery out to do this.
2. Hold the menu button in.
3. Still holding the menu button in, press the power button.
4. Keep holding both buttons in until you get a dialogue asking if you want to format internal memory ... say yes.
5. Your internal memory will be formatted and you will now be able to start your X20.
Try to figure out what file is causing X20 to freeze - i've found that pretty much any .m3u file will make it freeze on building library ... only about 2-3 out of about 100 i've tried have worked.
Oct 20, 2007 | iRiver X20 MP3 Player
Sansa seems to be frozen at startup
is my sansa broke or wat. when i plug the usb cord in the sansa comes on and wen i take it out it goes off , but the screen don't come on......i suffered the problem of wen the screen do come on it stops at the sansa rhapsody part then start over back to the big sansa screen then sansa rhapsody..........someone please help!!!!!!!!!!!!!!!!!!!!!!!
Sep 11, 2007 | SanDisk Sansa e250 MP3 Player
44 people viewed this question
Top Yes Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Yes Audio Player and Recorder Expert? Answer questions, earn points and help others
