Unhappy about the extra energy that is being used when only the inner ring is needed. New problem, with a fairly new stove (around 6 months old).
SOURCE: Whirlpool electric stove
the sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
SOURCE: The inner right front element
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
SOURCE: LG Range Element Will Not Heat
on my 30755 top left element will turn on but not adjust top right turns on to high only will not adjust . 3months out of warenty
SOURCE: Having trouble cleaning splatters off Ingis Glass Top Stove.
Use DeBruce Polish- a true multi-surface cleaner. There is a transfer of particulates from pan to glass surface aided by the heat. The cleaner will remove this "staining". Also use on stainless steel rubbing with the grain- this is the one product that truely cleans the surface. Follow up with baby oil or a stainless steel "polish that is oil based to "seal"the surface.
debrucepolish.com
SOURCE: Front left dual element on a Frigidaire ceramic
open the door and look under the top remove the screws and the top will lift
