Printing every few lines blurry, but not every line.
I have an Epson Stylus PHOTO R380, When I am printing text like a resume every 5 lines or so it prints the line blurry and then prints fine and then blurry a few line later again and so on.
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
If you're using a direct printable disc. Settings should be 24mm inner and 117mm outer. Also change the "Adjust print position" to 0.1mm up and 0.1mm left... this should center you. If you're using the stickers label outer should be 117mm but the inner you will have to adjust depending on the lable inner diameter.
You will have to keep collabrating the colors on your monitor until you get the right print out. If you're not using the right ink this will also throw off the print outs. Epson R380 is not really your avg high end printers so you will not get the best results. I suggest look for a monitor collabration software to correct your problem.
It must the nozzle check is not perfect. Check nozzle and do head cleaning procedure. If there is just little nozzle clog ( 1 - 2 lines missing), you can get good result with best photo/photo rpm setting.
I had this trouble, went through cleaning & realignment, then various print options. What i found was that dark colours had faint dark horizontal lines 5mm apart when printing on Photo in the epson driver. Changing it to Best Photo solved it.
My printer epson D88 is not printing all the lines clearly, some lines, about 10% look as though they have been ''rubbed out'' (partially erased) are you able to offer a solution please?
