Sounds like something happened with gas pressure?
Way high?
Absolutely, call somebody / a tech that knows how to test for gas pressures using a Manometer. Your Gas provider, should have a tech service dept.
Testimonial: "I had that checked and they said if anything it was a little low. Any other thoughts?"
SOURCE: I just replaced the control module and flame
This is backwards. The blower comes on first then after the air pressure is good in the exaust it will turn on the power to the ignitor and open the gas valve. If it is doing what your describing there is something wrong with the way it is wired. But many times people will mistake the noise of the blower comming on for the flame and the sound of the gas valve and the ignitor for the blower kicking in. This is probally the case. If you have water in the fire box this is a much bigger problem with your heat exchanger and it will do damage to other components. If this is the case it is time to replace the heater. All of this is symptommatic of bad water chemestry and you will need to address this or you will damage the new heater and chemecal damage is never covered by warrenty. Good luck.
