Welding Tools Logo
Lance Deen Posted on Jun 18, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need a manual for a rossi ct-312 welder
I need a manual for a rossi ct-312 welder inverter tig arc plasma cuttur
dannydoesita
Level 3:
  • Master 778 Answers
  • Posted on Oct 02, 2018
dannydoesita
Master
Level 3:
Answers
778
Questions
Helped
226830
Points
6375
Look up the company online with make and model #. The company should be able to help you. Good Luck Friend.
5 Related Answers
Anonymous
  • 2712 Answers
  • Posted on Aug 27, 2008
SOURCE: TIG welder help
Choose the electrode to use for the project you are starting as well as the variety of alloys you'll use such as the 6061 Aluminum alloy electrode. Grind the electrode to a point. Try to create a tip and sharpen it to help it become more rounded as you weld. Place the electrode into an electrode holder with the tip about 1/4-inch away from the sheath. Choose the settings on your tig welder. The three main ones are AC, DCEP and DCEN. Choose AC for aluminum. Slide the "cleaning/penetrating" slider more to the penetrating side. Set the "air on" to five seconds and the "max amps" to 250. Turn on the gas. For aluminum, use pure argon. For steel, an argon and carbon dioxide mix. Scrub your welding table or flat piece of sheet metal with a wire brush to make it clean and flat. Gear up in full welding safety gear including hood, goggles, apron and gloves. Hold the electrode in your dominant hand and start your welding project. Check your settings every so often to make sure they haven't changed and adjust as needed.
Anonymous
  • 169 Answers
  • Posted on Dec 03, 2008
SOURCE: Manual for a Cambell Husfeld welder Model WF2000
You can download PDF versions of the manuals for CH welders at the Campbell Hausfeld website.
Look on the left under the Service Center heading for a link to manuals.
Rank this answer if you found it useful,
Carl
GiantTechGuy
Larry
  • 25 Answers
  • Posted on Jan 19, 2009
SOURCE: GIANT 200AMP INVERTER ARC WELDER NO POWER TO THE LEADS
remove the fan from the circuit and try it then, does it weld ok with the fan removed?
Anonymous
  • 7 Answers
  • Posted on Mar 21, 2009
SOURCE: Miller TIG Welder Syncrowave 350XL has no digital read out...
it's free for you to download.
http://www.millerwelds.com/products/tig/syncrowave_350_lx/
GiantTechGuy
Larry
  • 25 Answers
  • Posted on Oct 18, 2009
SOURCE: my giant wse 200 tig inverter single phase AC/DC
Hi, remove the machines cover with the machine unplugged then look for disconencted plugs etc within the machine. careful where you place your bare hands.
What mig gun is on a Nevada 220BZ Mig Welder
Nevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder ...
www.ebay.com.au > Industrial > Welding > Welders
eBayNevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder Welding ... Nevada Welding machine; MIG Torch; Earth Clamp; Electrode Holder; Safety Mask ..
1helpful
Operating instructions thermadyne sa tig 200p ac/dc
Go to this site and you can download or print a manual for your welder copy and paste to google search engine and it has the manual on pdf. TRANSTIG 200 AC/DC Servic Manual - Victor Technologies
6helpful
Rossi 220BZ Gas/Gasless Inverter Welder MIG MAG ARC Portable Welding Machine
The Rossi 220bz mig welder comes set up to use gas welding, that is with the Mig electrode connected to the positive terminal, inside the machine.
To use gasless mig wleding, the mig wire must be disconnected from the positive terminal inside the machine and reconnected to the Negative terminal - inside the machine. Open both the side coveres of the welder using a phillips screwdriver. Use a 13mm spanner to undo the hex nut holding the thick copper Mig lead to the terminal named positive, then lead it through the machine to the terminal on the oppisite side of the machine, labelled negative and screw it in place there with a 13mm hex screw. Be carefull not to bump any of the many electric parts inside the machine.
If you run the Mig welder in gasless mode with positive earth and positive elecrode it will blow the household electric fuse.
If you run the Mig welder in gasless mode with negative earth and positive electrode it will work, but the end of the Mig gun tip will get very very hot and start smoking abnormally from excessive heat.
But if you take the side covers off and rewire it (takes about 10 minutes) to negative Mig Electrode, the Mig gun tip remains cool and does not overheat. You will have to cut just one white cable tie, to get an extra inch or so of free Mig cable, so the thick copper Mig lead will reach accross to the terminal on the other side of the machine named negative. Stick the earth lead at the front in the positive terminal.
I did this on my Rossi 220bz mig welder.
http://www.weldequip.com/gasless-mig-wire.htm
2helpful
Tusten tip keeps sticking what am i doing wrong i have rockworth inverter
Make sure the tungsten tip is sharp, not too far from the nozzle and try not to let it touch the metal or molten pool. Also make sure you have an adequate gas feed
Giant inverter tig mma111 230 volt
check if the load on it is not more than its capacity and check the batteries if they are still in good condition
Arc start board
At your nearest Miller distributor (almost all gaz reseller)
4helpful
Top Inverter Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you an Inverter Welding Tool Expert? Answer questions, earn points and help others
