Re: I would like to know the order in which the colored...
Impossible to answer this question with so little detail. In general you follow the coding on the board, which should show what wire goes where, but that assumes the wires are not in any way energized with power at the time.
2004 Hyundai XG350 Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red Car Radio Switched 12v+ Wire: White/Green
Car Radio Ground Wire: Black Car Radio Illumination Wire: Brown/White
Car Stereo Dimmer Wire: Green
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Black/Yellow
Left Rear Speaker Positive Wire (+): Brown/Red
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Black/White
here is the wiring
Constant 12V+White/Green
Switched 12V+
White/Red
Ground
Black
Illumination
n/a
Dimmer
Red/Black
Antenna
Glass
Front Speakers
6 1/2" Doors
Left Front (+)
Blue/Green
Left Front (-)
Gray/Black
Right Front (+)
Red/Green
Right Front (-)
Brown/Black
Rear Speakers
6" x 9" Rear Deck
Left Rear (+)
Blue/Yellow
Left Rear (-)
Gray/White
Right Rear (+)
Red/Yellow
Right Rear (-)
Brown/White
Constant 12v+ Wire: Green/Violet Switched 12v+ Wire: Yellow/Black
Ground Wire: Black/Light Green Illumination Wire: Light Blue/Red Antenna Trigger: Orange/Blue Amp Trigger Wire: Blue (If Equipped) Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Light Blue/White Right Front Speaker Positive Wire (+): White/Light Green Right Front Speaker Negative Wire (-): Dark Green/Orange Left Rear Speaker Positive Wire (+): Gray/Light Blue Left Rear Speaker Negative Wire (-): Tan/Yellow Right Rear Speaker Positive Wire (+): Orange/Red Right Rear Speaker Negative Wire (-): Brown/Pink
Hello ruben
These color codes are for the factory radio harness. there are 3 +power wires if you have a pwr antenna, this wire is pink. The ign/acc +pwr. wire is blue with black stripe, the radio memory +pwr.
wire is orange with a black stripe. Hope this helps.
2003 Kia Spectra Car Stereo Wiring Color Codes
Car Radio Battery Constant 12v+ Wire: Pink Car Radio Accessory Switched 12v+ Wire: Green Car Radio Ground Wire: Black Car Radio Illumination Wire: Red/Black Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): White/Green Left Front Speaker Negative Wire (-): White/Brown Right Front Speaker Positive Wire (+): Yellow/White Right Front Speaker Negative Wire (-): Yellow/Red Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Brown/Black Left Rear Speaker Negative Wire (-): Brown/Green Right Rear Speaker Positive Wire (+): Light Green/Yellow Right Rear Speaker Negative Wire (-): Ornage/Black
Here is a cheat sheet I compiled that you will find very helpful:
Plug Types/Application 7 Way - RV Trailers, Horse and Utility Trailers 6 Way - Horse, Stock and Utility 4 Way - Utility Trailers
Columns are Color, Function, Mark on the plug. Seven wire Trailer plugs:
Horse, stock or utility trailers: White = Ground - 1 Blue = Electric Brakes - 2 Brown = Tail and clearance lights - 3 Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Black = Battery, aux power - 4 Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
Horse, stock or utility trailers: White = Ground - GD Yellow = Left turn/Brake -LT Green = Right turn Brake -RT Brown = Tail and clearance lights - TM Red or Black (not both) = Battery, aux power - A Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark) White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT Green
= Tail and clearance lights -TM Black = Battery, aux power - A Red = Left turn/Brake - LT
Four wire plugs: White = Ground Yellow = Left turn/Brake Green = Right turn Brake Brown = Tail and clearance lights
Constant 12V+ White/Yellow Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Trigger Yellow/White Antenna Left Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6 1/2" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground dark green = left front spkr + purple = right front spkr + blue/white = right rear spkr - brown/blue = left rear spkr - brown/yellow = left rear spkr + blue/orange = right rear spkr + black/yellow = park lamps brown/red = left front spkr - orange = dimmer signal pink = fused battery + green/red = radio choke relay red/white = fused ignition blue/red = right front spkr -
there is a code for color!? ok, wait im searching... found it! here you go, hope it helps...
Wiring color codes are the identification colors that color the wires
in your automobile. For example, if you have a British car the blue,
blue and white , and blue and red wires are for the headlights. The red
and white wires are for the instrument lights, and the green and white
and green and red wires are for the turn lights. The color code simply
identifies what that wire does. Could you imagine if all of the wires
were the same color. You couldn't identify anything in a harness.
