Are you sure it's not 1355? The fault codes using the key on/off sequence are two digit codes, and code 55 means the end of the list. So it may be 13, 55. Code 13 means the ECU is not receiving a MAP (manifold absolute pressure) signal. See the link for the breakdown of Chrysler fault codes (bottom of page). Troubleshooting Fault Codes Chrysler Two Digit Computer Codes 1980s 1990s
Hello there again here is some more info for you Whirlpool Washer Troubleshooting: Error/Fault Codes
Whirlpool Washer Troubleshooting has been made easier since newer
Whirlpool washers generally display a consistent range of error codes
(or fault codes) when problems develop so that owners and service
personnel can quickly troubleshoot the problem and fix it easily. The
Fault codes address a wide range errors that occur with Whirlpool
washers, everything from water and power problems to basic maintenance
routines. We have put together a comprehensive list of Whirlpool Error Codes for some specific and general Whirlpool Washer models to help you with your Whirlpool Washer Troubleshooting task.on next post
The flashes are an error code. Count them till they repeat. Get a service manual and look up the error code. Some error codes prevent the set from powering up to prevent more damage. You can reset the code for troubleshooting. Repair as required.
