Refrigerators Logo
Roger Goforth Posted on Jun 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Temperature control panel
THE LIGHT OF OUR OLDER FRIDGE'S TEMPERATURE CONTROL PANEL LOCATED ON THE OUTSIDE OF THE FRIDGE DOOR, JUST TURNED OFF. THE INTERIOR LIGHT WORKS, BUT THE FRIDGE AND FREEZER SIDE DOES NOT GET COLD.
Claude Kayser
Level 3:
Top Expert:
  • GE Master 9,098 Answers
  • Posted on Jun 17, 2015
Claude Kayser
GE Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5066274
Points
28436
CHECK THE ON/OFF SWITCH ON THE INSIDE.
Maytag fridge bepping lights out MFI2568AES...fridge and freezer working..what could it be... Beeping all night long..
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
Cause of Beeping Noise in Frigidaire Refrigerator eHow Refrigeration System Basics Chapter 1
E240B Fridge Freezer door open alarm goes even when door closed.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
What setting must my fridge and freezer be at. Thanks
RFA70 settings Controlling the Temperature of the Fridge Compartment The left hand control wheel on the front panel adjusts the internal fridge compartment temperature. The internal temperature should be 5?C or colder, although some sections such as the salad bin will be slightly warmer. The setting of the control wheel will depend on the location of the fridge freezer, the room temperature and how often the door is opened. The normal set point (marked by a 3 on the dial) is usually suitable. If you need to adjust the temperature turn the control wheel using a coin to avoid damage: Clockwise (higher number) - Colder Anti-clockwise (lower number) - Warmer
Here is a user manual go to page 6 http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Fridges/HBRFA60.pdf
APPLIANCE 911
Model MF12266AES French door fridge seems to be stuck in defrost mode. We were told there is a way to 'reboot' the system on the fridge (maybe by pressing the light button inside a number of times). Does...
Hello Jennifer
Here is my step by step instructions to follow.
1. Look inside your refrigerator and locate the temperature control switch. This is usually situated around the middle of the refrigerator's back panel. Some switches have a wheel mechanism, whereas others use digital displays.
2. Turn the temperature control wheel down to zero or switch to "Off" if you have a digital display.
3. Move your refrigerator away from the wall. Refrigerators are extremely heavy, so enlist the help of another person, if possible.
4. Unplug the refrigerator cord from the wall outlet. Leave unplugged for around two or three minutes.
5. Attach the power supply back to the wall outlet and position the refrigerator back against the wall. Your refrigerator temperature is now reset. Switch the temperature control back to "On" and adjust the temperature to the level required.
6. Open the ice making area of your refrigerator if it is producing watery ice cubes or an inconsistent water supply.
7. Locate the water filter status light inside the ice maker. This is usually a small rectangular light situated at the side of the ice maker.
8. Push the switch next to the status light seven or eight times in quick succession. This will reset your ice maker.
9. Check the status light. This should turn from red to green once the switch has been pressed several times. The green color indicates the ice maker has been reset.
Remember if you FRIDGE is on warranty you just send it first to the manufacturer.
Best Regards
Neciforo Llanto
2helpful
The fridge is blowing the 12 volt fuse as soon as I power up the motor home, The fridge is turned off and it still blows the fuse, I tried to undo the 2 wires that go to the 12 volt block on the fridge and...
Unplug the wire located at terminal J4 (12v positive) on the control board, and see if you are still popping fuses. If so, then the fault lies between the wire you just removed and the fuse that keeps blowing.
If the fuse holds, and blows when you plug the wire back onto J4 terminal, then unplug the wire(s) at J2. These go to your door heater (used in humid conditions to remove condensation), as well as the interior light. The switch for the door heater is located on front panel, or is at the top edge of the freezer compartment with door open. It is not unusual for this switch to have issues since it gets chilled and moisture condenses on it. If unplugging the wires at J2 allows the fuse to hold, you probably got a shorted heater or bad heater switch. But, pull the lens off the interior light, and check the contacts there as well.
If the fuse still blows with J2 removed, then unplug the connector in the top left corner of the control board. This goes to the control panel on the inside of the fridge. If the fuse blows, replace the control board. If the fuse holds, the replace the control panel.
Refrigerator not getting cold even when set at lowest point.
Not enough information. But here is something which may help you diagnose the cause. I assume that you have a frost free fridge freezer. That there is a fan in the freezer which blows cold air down into the fridge.That the freezer is still cold. You can hear the fan cutting in and out.
Try opening the Fridge door and locate the little plunger switch which is pushed shut by closing the door (like the switch on you car door that turns the interior light on and off).
Push it in manually with your hand. (the fan needs to be running. The fan should blow cold air into the fridge. There will be a panel with vents, probably on the back off the fridge. Cold air should be coming from this. When working properly the temperature sensor in the fridge will control a flap like valve to allow or disallow entry of cold air from the freezer to the fridge.This controls the temperature of the fridge. If the flap is jammed shut no cold air can enter the fridge. Likely cause is ice build up, most likly in the back of the freezer blocking the path of the cold air. I had this problem on an old fridge of mine.I think that it is caused by the heat cycle not kicking in correctly to defrost the heat exchanger . I used to DISCONNECT THE FRIDGE FROM THE ELECTRICAL SUPPLY dismantle the inner panels of the freezer. And pour water over the ice monster blocking up the back of the freezer. Not a good solution i grant you. But it would work for a week or two. Then i would have to do it again. later i found a small panel on the back (outside) of the fridge with wiring and stuff inside it. There was a rotatable knob which clicked as you turned it. in one position you could hear it make the heat cycle kick in manually. I spent about 6 months doing this every few days whilst saving for a new fridge. It worked. But there is a RISK OF ELECTROCUTION .
Sorry i cant fix your problem . But this might be of some help to diagnose it. If you are not sure i wouldn't recommend fishing round in the electrics. I have had quite a few electric shocks doing stuff like this because i am not as careful as i should be, and i am not a qualified electrician. It never hurts me much. But some people will die quite easily from mains voltage. BE CAREFUL!!
2helpful
3answers
Fidge beeps and warning door open comes on, temp fluctuates
I had this exact same problem. I replaced the PCB on the freezer. Cost approximately $100.00. Problem solved. No flashing door light, no fluctuations in temperature. YAY.
6answers
Fridge working intermittently.
i guess there is some problem with the thermostat
get it changed.....
5helpful
Bosch Fridge Freezer Classixx
This button is the winter/summer setting.
If you switch it on so as the red mark shows this is set for the summer setting.
What it does is allows the interior light to come on very dimly when you shut the door.
The fridge then thinks it is too warm and starts to cool down more, designed for when the ambient temperature is high.
Hope this helps
Deep diver
Top Refrigerators Experts
vince
Johnny 1000
