Canon Ir 400 copier E000 Error plz to remove error
Try the link below. It says that in a nutshell the fixing temperature is not coming up to spec or even increasing. Another site I found said to try resetting the machine first, from the control panel. The page below also describes likely causes, if you are a technician, this may help. Otherwise, it would be best to refer it to a qualified service tech. Good luck!
iR 400 Code List
SOURCE: ir 2000, system error E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
heater goes ON. (fixing low temperature error)
If E000 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Entering service mode: press "aditional function" and after "#(ID)"
SOURCE: copier canon ir 1600
Problem with fixing Unit, simple simulation will help. otherwise need to change fixing unit,, contact ur service engineer
SOURCE: Error E000
E000: FIXING UNIT PROBLEM
replace or repair the fuser unit:
The fixing temperature is very low:
• The thermistor has poor contact or an open circuit.
• The fixing heater has an open circuit.
• The thermal switch has an open circuit.
