2002 C320 Logo
d
don miller Posted on Jun 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2002 mercedes c320 how to code to car sam in trunk
Sean Piquet
Level 3:
  • Mercedes-Benz Master 1,867 Answers
  • Posted on Nov 19, 2015
Sean  Piquet
Level 3:
Answers
1867
Questions
Helped
610971
Points
7259
1 Related Answer
richardvreed
richard vreede
  • 432 Answers
  • Posted on Mar 26, 2015
SOURCE: How can I change license plate lights on my 2002 mercedes c320
What a question and read your manual...... and don't forget to put the gasket on it's place again. I assume you didn't google first since there are plenty of mercedes forums, which also are too lazy to take a look themselves.
Where is the air pump located on a 2002 mercedes c320
hi have a pic of location but cant seem to attach it or upload.
Dec 22, 2015 • 2002 C320
Mar 25, 2015 • 2002 C320
No power at fuel pump
Did you test for power at the fuel pump while cranking the engine? Also did you use a good source for a ground? You can also check the fuel pump relay in the rear SAM Control unit in the trunk, position "A"(top relay).
2002 c320 radio and cagarite lighter do not work.
Had the same issue on 2002 c320 . look at the fuse chart ,find out the fuse # that operate the radio and the cigarette lighter , you have three fuse boxes, engine compartment, driver left knee and trunk on left .find the fuse b compairing the char to the box , replace the fuse . DONE
3answers
Mercedes 2003 C320 something is draining battery
Check to be sure the trunk is closing all the way. It happened once to me - someone slammed my trunk shut and after that it would not close all the way. Never slam a Mercedes trunk!
2002 Mercedes C320 very poor fuel economy ~8 mpg, no engine codes or faults present
Lead foot, tire pressures, stop /go driving. AC/poor compression, Trunk full of sandbags, transmission slipping, Wheel bearing friction, Brake shoe always on, etc.
2002 c320 benz key died
That sounds reasonable to me.
The key in the ignition to my mercedes 2002 c320 will not turn
Just replaced my key the ignition switch and the esl in my c230 98 Benz. Worked for about a week and now the esl will not unlock the steering or start the car. Is there any way to reset the esl? All three components are new I don't understand the problem .what causes the esl not to engage when you put the key in the ignition
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
