It doesn't run rough all the time but seems to start usually after it's warmed up I've changed the plugs ,wires,coil pack, crankshaft sensor
Definition of Diagnostic Trouble Code P1506
Audi:
Closed Throttle Position Switch Does Not Open/Short to Ground
BMW:
Idle-Speed Control Valve Opening Solenoid Control Circuit Signal High
Ford:
Idle Air Control Overspeed Error (see P0507)
Jaguar:
Idle Air Control System RPM Lower Than Expected - B Bank
Kia:
IAC Valve Opening Coil Voltage High
Lincoln:
Mazda:
Mercury:
Porsche:
Throttle Jacking Unit Lower Mechanical Stop, Signal Implausible
Volkswagen:
Volvo:
IAC Valve Opening Signal
Definition of Diagnostic Trouble Code P1151
Audi:
Bank1, Long Term Fuel Trim, Range 1 Leanness Lower Limit Exceeded
BMW:
Oxygen Sensor Heater Circuit Signal Intermittent (Bank 2 Sensor 1)
Ford:
Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Lean
Jaguar:
Lack of H02S-21 switch, sensor indicates lean
Land Rover:
Lambda control limit bank 2.Implausible signal/condition
Lincoln:
Mazda:
Mercury:
Subaru:
HO2S-12 Heater Circuit High Input
Toyota:
Coolant Path Clog Up for Coolant Heat Storage System
Volkswagen:
Definition of Diagnostic Trouble Code P0302
Category:
Powertrain
Definition:
Cylinder 2 Misfire DetectedNote: This definition of P0302 is applied to all manufacturers
Definition of Diagnostic Trouble Code P0171
Category:
Powertrain
Definition:
System Too Lean Bank 1Note: This definition of P0171 is applied to all manufacturers
