Its has to be for a 2012 Hyundai Santa fe
SOURCE: camshaft position sensor location
crank sensor is a component used in an internal combustion engine to monitor the position or rotational speed of the crankshaft. This information is used by engine management systems to control ignition system timing and other engine parameters. Before electronic crank sensors were available, the distributor would have to be manually adjusted to a timing mark on the engine.
The crank sensor can be used in combination with a similar camshaft position sensor to monitor the relationship between the pistons and valves in the engine, which is particularly important in engines with variable valve timing. It is also commonly the primary source for the measurement of engine speed in revolutions per minute.
Crank sensors in engines are usually comprised of magnets and an inductive coil. They are principally based on the Hall effect. Common mounting locations include the main crank pulley, the flywheel, or occasionally on the crankshaft itself.
Some engines, such as GM's Premium V family utilise crank position sensors which read a reluctor ring integral to the Harmonic Balancer. This is a much more accurate method of determining the position of the crankshaft, and allows the computer to determine within a few degrees the exact position of the crankshaft (and thereby all connected components) at any given time.
SOURCE: location of crank position sensor 2003 santa fe 4
hi the sensor is in with the timing belt. You will have to remove the timing belt cover and belt to put a new one in. You will also see a small gold metal rotor that spins on this sensor also replace that or it will trash the new sensor.
SOURCE: ''check engine light'' illuminated, 1004 Hyundai, Santa Fe
If you live in the US, take it to qany Auto Zone store and thy will read the codes off for you, I would suspect any right thinking competitor would do the same, check if you don't have one near by.
Hope this is of some help.
Ed
SOURCE: would like to see a diagram of where exactly the
Which engine?? V6 or the 2.4I? The V6 CKP is in the engine block near the flywheel side of the engine (behind and lower right of the exhaust manifold nearest the radiator) A 10mm bolt holds it in place. On the 2.4 4cylinder, the sensor is at the front of the engine behind the Timing Belt cover at the crank shaft. To replace it, you have to remove the timing belt, but you also need to know some technical things to reinstall the belt to be sure you are installing it correctly. Go to http://www.hmaservice.com/ and register. You'll then have access to lots of technical info and manuals, wiring diagrams, etc. about your vehicle.
SOURCE: Change serpentine belt 2004 Hyundai Santa Fe
it uses a spring loaded tensioner.use a breaker bar to rotate the tension and it should just come off.if u need a pic or anything else to do it let me know,
