Home Security Logo
Kumar Das Posted on Jun 15, 2015
Forgot admin password in Hifocus H264 DVR, unable to enter main menu
Hi-Focus H 264 DVR Forgot admin password in Hifocus H264 DVR, unable to enter main menu
  • pinoy tekniko Jun 19, 2019
    must try this login account: admin password: 130901
  • Anonymous Jan 19, 2022
    It didn't work
M.A Cardoso (Interside)
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on May 14, 2016
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
44835
Points
54
Hi. Put here some images of the DVR's front side, the login screen and the WEB interface.
I forgot my dvr password.How to reset my dvr hifocus hd 404an .
To reset password of your CCTV DVR press and hold the ENTER button for 15 to 30 second until the DVR restart's. After the restart you DVR default wizard will come up the same way like if you are setting up the DVR for the first time.
https://www.youtube.com/watch?v=dmspTHBS7e8
Hai my hi focus xvr password forgot how to reset it
Remove LAN cable if it is attached
Restart you DVR
Choose the "admin" account in USERNAME
Use MASTER PASSWORD in PASSWORD. Now you can access your DVR
Go for Main Menu >Advance > Account
Select "admin" user
Click on Modify Password, In Old Password Use Master Code,
In New & Confirm Password type your new password (without any special characters).
Now you can login with your NEW PASSWORD that you have created.
1helpful
2answers
I forgot my admin password i got a H.264 dvr 4ch China made
Admin and Passwords come as default. If you changed it and forgot, try unplugging the DVR and restarting. You can also still open the settings and try to re- factory the DVR if the settings permit. Next, I have to assume that you got the Booklet or the email or URL addresses to download same.
There is in the hand book the default password as the User name:password and the Password #'s 1-6. Good luck.
1helpful
How do i find the defult sender password to set up my H.264 DVR
Open up the password browser and enter...519070 that's the Default. I have years of experience with the night-owl system.
INSKIP
Kare DVR Password help!
Forgetting password please i need your help thanks
3helpful
2answers
Forgot login password
Default User and Password on Everfocus is usually
Admin
Admin
Nevertheless, you should contact your local distributor, and after providing the product serial number, they can generate a reset user and password, that shall be used only once, and then, you must enter a new user/password combo.
Cant access menu on defender sn301-8ch
Some things to Try:
Installer Master Code 1397 Selecting this accesses the Main menu. If the menu is locked, you may need to unlock first. To unlock the menu: Select the area the password will be typed and a digital number pad will appear. Type in the password. The default password is 123456. Once you have typed in the password, press the enter button to close the digital number pad. Click "APPLY," if the password is correct the main menu will open. Unlock Menu Prompt Password Setup This menu selection allows you to change the device ID, enable password protection as well as set a new password for users and admin on your DVR. When you enable password protection, you will be prompted to insert a password each time you wish to access the main menu. The DVR will automatically log the user of admin out after 60 seconds. To Change the Device ID: 1. Select the box next to "device ID" and a keyboard will appear. 2. Type the name you would like then select enter to close the keyboard. 3. Select "apply" to save your changes. To Enable Password Protection: 1. Select the scroll bar next to "password enable" and list will appear. 2. Highlight and select "On" to turn the password enable on. 3. Select "apply" to save your changes. To Change the Password You have the option to change the password for user and admin. A user will only be able to access the search menu to view saved footage, whereas an admin will be able to access anything in the menu. Both default passwords are set to 123456. 1. Make sure password enable is set to "ON". 2. Select the ****** box next to the password you would like to change and a keyboard will appear. 3. Type the password you would like then select enter to close the keyboard. 4. Press "Menu" and highlight "Next" to confirm. 5. Type in the same password again, next to "confirm" in order to confirm the password then select enter to close the keyboard. 6. Once you have entered the desired password, select "apply" to save your changes close the keyboard.
HOPE THIS HELPS!~
How do you reset the admin password on a truvision dvr 30 16 channel.
how do i reset admin password on a truevision dvr.
I have changed it and i forgot it
217helpful
6answers
I need reset the password on a 16 ch. dvr dvs do you know how i can do this?
I have a H.264 Network DVR with ver. V2.00.R05 and I've forgotten the password can anyone help with resetting it...
Mikw
Top Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Home Security Expert? Answer questions, earn points and help others
